Question about Ovens
Self cleaning oven whirlpool
When I press the AUTO CLEAN pad on my Whirlpool Stove the following appears on it cln hold and I cannot get it to start the self-cleaning process as the "cln hold" stays on a short time then it returns back to the clock and the time of day. How can I get my Auto Clean to start again? I am sorry but I have misplaced my instruction book. Thanks...thecarlson@iamotelephone.com
  • ovencleaner Nov 17, 2007
    i have aquired a whirlpool self cleaning stove but the instruction booklet did not come with it how do i clean the oven
  • 13 Answers
SOURCE: RENTING CONDO WITH SELF-CLEAN WHIRLPOOL OVEN RF376PXDQ
If this a relatively new oven it show have a self cleaning identification on the control area or panel. Just close & select self cleaning option should take about 1 1/2 - 3 Hours
Posted on Mar 25, 2009
  • 291 Answers
SOURCE: I have an old Whirlpool Self-Cleaning oven. I've
Probably, in some models both the bake and broil come on to help it heat faster and hotter. In some units the self cleaning light will not come on until a certain temperature is attained. Are you setting the start time for right now, and the stop time for 2 to 3 hours from now?
Posted on Jan 28, 2010
  • 166 Answers
SOURCE: cannot find my book, need to remember how to start
Usually a lever hidden right under the cooktop above the door that needs to be flipped to lock the door closed. then you set it to clean and let it go for hours.
Peace,
Posted on Feb 27, 2010
tbirdfan1
  • 3051 Answers
SOURCE: Whirlpool Oven will not heat
Hello there:Usually,
when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. bullet.jpg If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. bullet.jpg Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Posted on Jul 25, 2010
tunde007
  • 2382 Answers
SOURCE: Have Whirlpool oven,self cleaning,no guide
Hi, the E1-F5 error code is a door lock error. It means that the oven is sensing that the door is not securely closed. Could be a bent latch or some other trouble. Unplug the range for 15 seconds and see if that clears the code. If it does not clear the code, then the Latch to the door, or switch is failing causing the error door message.
Troubleshooting the Oven...
  • Press "Off/Cancel" to clear the display, engage the door latch and try to turn on the self-clean cycle. If it works, it was just a momentary short. If the error code reappears, the problem could be either the door hinge assembly or the door latch.
  • Open the oven door as far as it will go, and close it slowly and smoothly. Try to wiggle the door side to side by tugging on the handle. If it does not move, the latch is the problem. If it does move, tighten the screws on the hinges located at the bottom of the door until they are secure.
  • Locate the door stop clip, a small piece of protruding metal immediately above the left door hinge. Inspect the clip for any twisting or foreign objects. Straighten a twisted clip with needle-nose pliers, remove foreign objects, and wipe the clip and both hinges clean with a damp cloth. If either door hinge is bent, replace both.
  • Close the oven door and engage the door latch. Press "Off/Cancel" to clear the error code, then try to start the self-clean cycle. If it works, you've fixed the problem. If the code reappears, the door latch assembly must be replaced. If your warranty is still valid, do not attempt any further repairs - contact a service center.
  • Unplug the oven and turn off the gas valve. Open the oven door and locate the screws that hold the control panel and cooktop in place. These are located inside the upper rim of the door stop. Remove these screws and lift the cooktop.
  • Look at the inside front rim of the cavity. If you see a lock mechanism with no wires, you can replace it yourself. If you do not see a recognizable lever assembly, or if the assembly includes a small black box with wiring, your oven has a special type of lock that requires certain equipment and training to service. Contact a repair center.
  • Remove the entire cooktop. On some models, it slides directly toward the front and lifts out, on other models, it tilts up and lifts out. Set it aside. Remove the screws holding the latch assembly in place, lift the assembly out and discard. Replace with a heat sensitive latch assembly for your model. Tighten screws securely, and test the latch before you replace the cooktop.
  • Place the cooktop back into position. Make sure the back portion is secure. Replace the front screws. Plug the oven back in, turn on the gas, engage the new latch, and try to run a self-clean cycle. If it does not work, or if the error code returns, contact a service center.
Posted on Jan 01, 2011
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
How do you use the self-cleaning ??? i lost my manual within minutes of getting....
we have a sears kenmore model and this is how we do it. remove everything from stove including the racks, close oven door, slide door lock latch to the right till it locks the door. turn knob to clean. when it is done cleaning it will turn off by itself. on some models the door latch will not slide open when done. just wait for it to cool if this is the case. it should tell on the touch pad on stove the hours that it takes to clean it. good-day !
Jan 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    How do I get self clean to work on older fridgidare stove
    Move the safety lock/lever at the top of the oven door to the right and press the self clean button on the oven control panel, it is an automatic cycle so it will lock the door from opening and then will proceed with the auto clean cycle. Good luck !
    Jan 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    I have a Whirlpool stove (model# RF385PXE)and I tried to start the self clean oven cycle the letters "door" appeared along with "E1" and "F5". The door is closed all the way. I even tried pushing it closed...
    HI. This code is an indicating that the Self clean latch will not lock. Lock mechanism failure. follow the procedure below to address further.
    1. If door latched:
    A. Disconnect power from unit.
    B. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
    C. Replace door switch.
    D. Re-apply power.
    E. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
    2. If door not latched:
    B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
    C. Repeat steps A and B for door switch.
    3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
    4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
    5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
    6. If failure remains, disconnect power and replace control.
    Nov 16, 2009 | Ovens
    When I try to start the self-cleaning oven, ''door'' appears in the display, and then the display goes to F5 E1. The door doesn't even try to lock. I have a Whirlpool Self-cleaning electric range Model #...
    there are switches under the cooktop that go bad frequently. i do not recommend ever using the self clean mode in an oven. the oven gets so hot that things have a tendency to melt because they dont build stuff like they used to. there is inadequate insulation in modern ovens. use easy off and follow the label directions. it'll be cheaper in the long run, trust me.
    Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    HOW TO ADJUST THE OVEN THERMOSTAT ON A WHIRLPOOL GAS OVEN MODEL SF387PEYQ7. THANKS AJ
    Press and hold BAKE pad for five (5) seconds. Current offset, if any is shown in 3-digit display. CAL is shown in 4-digit display (3 digits on right).
    Pressing the UP pad adjust the temperature in 10 degree F increments in fthe following sequence: 0, 10,20,30,-30,-20,-10, 0 and so on.
    Press START/ENTER pad to activate the desire tempature adjustment. If the START/ENTER pad is not pressed within 5 minutes, adjustment is ignored.
    May 08, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Ovens Logo
    137 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
