Question about DeLonghi Dehumidifiers
DEM 8.5 Delonghi flashing pause light
When I turn on my dehumidifier DEm 8.5 the *-C/Pause light is continious flashing.
Does someone have a solution???
3 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: DEM 10 Delonghi Dehumidifier has Stopped
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Posted on Aug 17, 2010
  • 259 Answers
SOURCE: Dem 10 Delonghi Dehumidifier not working
have you tried turning it to a higher setting ??
Posted on May 03, 2009
I just bought a second hand DEM 10 DEHUMIDIFIER. After starting it up (on every setting) the motor cuts out after a few minutes. All filters are clean. Please help. Kind regards Scott
assuming you have ck'd the water collection bucket full switch for proper seating , im sorry to say that short cycling on compressors are a sure sign of low gas pressure , and no its not easy to add more
Nov 20, 2016 | Dehumidifiers
Pause light is constantly flashing
Pause is not a term ive seen on a dehumidifier , but one would assume that its waiting for something to occur in that mode , and with these the only logicial reason to wait is to "wait" for Moisture to return to room , maybe your room has been voided of %rh to the setting on unit and its waiting for more water to return ??
Dec 13, 2014 | Dehumidifiers
Delonghi Dem 10 dehumidifier has stopped working - the 'operational light' turns on, but the fan does not start up so nothing happens.
It could be that the fan / fan motor has seized or jammed. Have a look through the vents and see if you can spin the fan. If not, you will need to strip the machine. Try lubricating the bushes / bearings. Often on these type of units, the vapours dry out the bushes and then they get tight and jam the fan.
Nov 08, 2013 | DeLonghi Dehumidifiers
DeLonghi Dem 10 dehumidifier stopped working - the 'operational light' turns on but the fan does not start up.
You may need a new fan motor. If you can get to this
motor, with the power disconnected, see if the blade
is free to move. Do you hear any sound coming from
this unit?
Nov 08, 2013 | LG DH30 GoldStar Dehumidifier
I have a delongji DEM 10 dehumidifier and it keeps switching to pause, I have cleaned filter switched off for a while but it still won't come on
follow this steps and fix it. God bless you
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself. If your unit is running constantly yet there is no water in the tank, try lowering the temperature control. If the problem persists, there may be a problem within the refrigeration system. You may need to pull the filter and clean it. Also try wiping off the unit itself. When the water tank is full, the unit will shut off and will not run until the tank is emptied. The dehumidifier shuts off by a safety switch in the back of the unit. If the switch is not working properly, you may try manually pressing the button or slightly bending the switch.
    Motor If the fan motor is damaged or will not work, no cool air will be coming out of the dehumidifier. The unit, however, may still run. You may need to replace the motor. If the coils in the back of the dehumidifier constantly freeze, try turning off the unit for an hour or re-locating the unit to a higher position to allow the room to heat up. If your water tank is constantly full and you are emptying it on a daily basis, you may have a water leak somewhere in the room with the dehumidifier.
    Oct 30, 2013 | DeLonghi DE500P Dehumidifier
    I have a delonghi des 14 dehumidifier. Usually it goes into pause mode for 3 mins when you first turn it on with the yellow light on and then starts dehumidifieing.It now stays in the pause mode forever...
    Just fixed this problem with my DES14. Its a fault with the circuit board inside the machine and is very easy to fix, even for a novice. Here is how to do it:
    1) Open up the machine by removing the screws in the case. (Make sure it is unplugged!)
    2) Locate the circuit board on the side of the unit.
    3) At this point you have two options. If you want a unit with full functionality you need to buy a replacement circuit board. I found one on MasterSpares (http://www.mastersparesonline.com/product/index/10147) It costs about 30 pounds. Simply remove the old board and replace it.
    4) If you want a working unit for no extra cost (but without the functionality of the humidistat) then remove the rectangular white connector from the circuit board which has red,blue,white and yellow wires entering it. Add an extra wire between the central white wire and the red wire that is adjacent to the yellow. (see photo).
    5) Re-assemble the unit. If you have opted for the free option the unit will work when you plug it in and switch it on but will no longer cut in and out with different humidities (or have the annoying warm up period). Thankfully the water overflow cut-out will still work.
    Hope it works for you! Feel free to ask if you are confused!
    Nov 13, 2012 | Dehumidifiers
    DEM 10 Delonghi Dehumidifier has Stopped collecting water but still seams to be working
    Take care.
    Aug 14, 2010 | DeLonghi Dehumidifiers
    My DeLonghi dehumidifier model DE500P is tripping the breake
    the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
    Apr 25, 2010 | DeLonghi DE500P Dehumidifier
    May 03, 2009 | Dehumidifiers
    Dehumidifiers Logo
    270 people viewed this question
    Top DeLonghi Dehumidifiers Experts
    dennis lewis
    Level 1 Expert
    Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
