Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
How to remove and replace door seal on a hotpoint wt 741
  • 31 Answers
The door seal are hard to do just take a good look at it befor you take it off you can take the frount panel off the washer to do this job give your self a few hrs so you dont rush
Posted on Jun 28, 2009
We wish to replace the rubber doorseal on Hotpoint WMA42P. I can remove the door seal ring but cannot quite see how the drum seal is fixed. Is it the same system with a sprung ring? Martyn
The following video is of a Hotpoint WF door seal replacement which is the same as the WMA series except the fascia panel is slightly different, make sure you take a photo of the wiring connections before you remove the fascia so you know where they go when you replace it
http://www.selfix-uk.co.uk/Video_page_washing_machine_door_seal.html
Jan 04, 2017 | Hotpoint Washing Machines
I need to replace the rubber seal on my Hotpoint ice diamond freezer door I can't find any fixing screws on the inner door panel can I assume then that the panel clips on.
Me too, I have a Hotpoint Iced Diamond Under counter fridge that needs a new seal and i also cant see any fixings to remove it. I did read somewhere that you can't replace them you need to buy a complete new door.
Dec 14, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Can i replace the bearings myself on my hotpoint ultima wt 741? thanks.
You can, but it is a long and involved repair, not recommended omless you are competent to do so, it involves a complete strip down of washer, not a task to be undertaken lightly.
Nov 28, 2010 | Hotpoint Washing Machines
Fit a new door on a washing machine
You need to remove the wire clamp that holds the door seal on to the front of the cabinet, then pull seal off.
This will give you access to the door hinge assy, then you can replace the door complete.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Hotpoint Washing Machines
How do I remove and then replace a new door seal on my hotpoint WD420 washer / dryer
First switch off electrics , Remove door interlock , leave wires on .remove soap dispenser,remove front panel with controls 3 screws top of machine 3 screws bottom remove front casing you can now see door boot. remove sring note how boot came off refit is oposit to this noting top / bottom of seal ..Hope this some help-
Oct 03, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint wma40 door seal
The black grime is mold. Once it is set into the rubber it is nearly impossible to remove. Bleach would have been my suggestion but since you've already tried that, replacing the bellows (door seal) is your next option. In the future, when the machine is not in use try keeping the door slightly open for any standing moisture to evaporate.
Feb 19, 2009 | Hotpoint WMA40 Front Load Washer
How to replace door seal of Hotpoint WF860 washing machine
Hi, This is a very simple and straight forward job. First turn off the washing machine and remove the plug from the wall and earth the plug on the cabinet of the machine to remove any residule current in the machine. Remove the top of the machine with the screws at the rear of the machine. You can now look in the top? Open the door and take off outer door seal clip ( look and you will see how ) If it is a plastic clip it will have a small cut out in the side for a small screwdriver to be put in a pushed open. It could even be a small spring that is laying in side the small lip of the door seal. You could now attempt the removal of the door seal if you can see the inner clamp to get a long screwdriver onto the screw! If not now remove the soap drawer. Remove screws from around the soap drawer and slide the facia to the right and it should all be off.. Then you can remove the three screws that hold the front on along the top and the same along the bottom edge of the front panel. This then will allow you to take off the front panel and have better access to the door seal. Then once you have replaced the door seal you just need to replace as you took off..
Good luck................
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
I Have a Hotpoint WD860P washer dryer and I have to replace the door seal but for some kind of reason I can't get the top of the machine to get the old door seal out...are there any screws in the fron...
I found out that you just have to slide the top bit to the back after removing the two screws at the back of the washing machine. I called a friend and he replaced the door seal in the end
Aug 14, 2008 | Hotpoint Washing Machines
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
177 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
