3 wire plug,middle wires goes to middle terminal,each of the other 2 wires goes 1 on each side,does not matter which one but the middle wire must go on middle terminal,4 wire plug-the white wires goes to the middle terminal,the red goes to red and the black goes to black,the green wire must be mounted the the case-mike
The dryer stopped working in the middle of drying a load of clothes.It won`t start at all now.If I...
(More)
The dryer stopped working in the middle of drying a load of clothes.It won`t start at all now.If I turn the timer switch to the "cotton" setting,and turn the start switch,there is no ticking sound from the timer. When I turn the select switch to "regular" setting and turn the start switch and hold it on you can hear the timer ticking down,but the dryer won`t start. If you let go of the start switch,there is no ticking from the timer switch.
Dryer Does Not Turn On. Worked before, but does not now. Turned the on/ off knob and nothing...
(More)
Dryer Does Not Turn On. Worked before, but does not now. Turned the on/ off knob and nothing happens. Tested continuity across on/off switch (knob) and shows that switch is good. Is there a fuse in the circuit?
