Question about Ovens
Oven not heating up past 200 degrees - Ovens
    President:
  • 632 Answers
Temperature controller not working properly..adjust sensitivity of sensor..
Posted on Jun 28, 2009
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven won't heat up past 200 degrees
The temperature sensor needs to be checked.It must not working properly. thanks.
Oct 11, 2011 | GE JTP45 Electric Double Oven
The oven is not warming up past 200 degrees and it is taking a long time for it to even reach 200.
Hello, Thank You for using FixYa. I will be helping you today.Your oven ignitor is bad. Replace the ignitor.
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Ovens
My oven wont heat up past 200 degrees. Suggestions
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Mar 04, 2011 | GE Monogram® ZMC1095BFBB /...
Oven doesn't preheat over 200 degrees
heatman101
Jan 04, 2011 | Maytag MEW5527D Electric Single Oven
Oven won't heat past 200 degrees
Unplug the range.
Remove the oven racks.
Remove the screws on the bake element.
Carefully pull the bake element out.
Remove the wires from the element.
Use a volt meter set for ohms/continuity and touch one meter lead to one element terminal and the other lead to the other element terminal.
No reading is a bad element/
If you get a reading your oven control is bad.
Jul 24, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Magic Chef oven won't heat up past 200 degrees
You obviously have one or more elements not working, you need to test same, and replace as req'd.
Dec 12, 2008 | Magic Chef Ovens
GE JKS06 won't heat up past 200
Hi.
Could be that main oven stat is faulty, and also there is a possibility that the thermal overheat stat is coming in sometimes caused by poor ventilation.
Also there is sometimes a secondary element fitted to cookers which is not always obvious.
More investigation is needed.
Nov 19, 2008 | GE JKS06BFBB Electric Single Oven
Ovens Logo
180 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
