Question about Sherwood RX-4105 Receiver
How do you wire speakers to the receiver - Sherwood RX-4105 Receiver
  • 66 Answers
Red is positive and black is negative its just that easy
Posted on Jun 28, 2009
How do you reset the TX-SR603X receiver? Will that help? my receiver turns on then shuts right off
Try thiThe most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps. s.
Sep 19, 2010 | Onkyo TX-SR603X Receiver
I have a Insignia receiver, connected to it is two rock speakers, when ever I connect the right rock speaker, the receiver turns off
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
Jun 15, 2010 | Insignia 200W Stereo Receiver
Sony STR-GX800ES receiver "protector" blinking - no sound
Jun 11, 2010 | Sony STR-GX800ES Receiver
The receiver turns itself off. the volumn is unstable
Jun 08, 2010 | Onkyo TX-SR703 Receiver
When I turn on the receiver it flashes the word
Jun 02, 2010 | Sony STR-DB1070 Receiver
The signal select is set to analog but it still turns off when the volume is slightly turned up, can you tell me why?
Sounds like the receiver is defaulting to "protect mode", this indicates that there is an electrical short present in the system, I have found that speakers or speaker wires tend to be the cause often.
Disconnect all speaker wires at the back of the receiver, turn receiver on and raise the volume control and see if the receiver still shuts down, if the receiver doesn't shut off, then one of the speakers or speaker wires are bad, reconnect one speaker at a time, raise volume and see if the speaker you connected causes the receiver to shut down, if not continue connecting the speakers one at a time, testing to see if the receiver shuts down after each speaker connected, when the receiver faults to "protect mode" again after you have connected a speaker then you know that the last speaker you connected is the "blown" or shorted speasker or wire.If the receiver still shuts off after disconnecting all speaker wires, then either one of your sources has a problem(DVD,CDplayer,cass deck,etc.) or the receiver has an internal short that will have to be repaired by a servicer.
Good Luck !
Feb 14, 2010 | Pioneer VSX-D412 Receiver
Power cuts off after 2 seconds after stereo start button is pressed
Disconnect your speaker wire's from your receiver, and then turn the receiver on.
If your receiver cuts off with the speakers disconnected, there is something wrong with your receiver, and take your Sherwood receiver to a qualified reputable technician.
If your receiver stays on with the speakers disconnected, their is a short circuit either in your speakers wires, or in your speakers. Make sure your speaker wires are pushed all the way in the speaker terminals in the back of the receiver, and do not leave no naked speaker wires exposed. If you have too long of bare speaker wires exposed at the receiver's speaker terminal, or at the speaker's terminals, they could touch each other, and cause the receiver to cut off. If the speaker wires are OK, then you may have a short circuit in your speakers.
Nov 12, 2009 | Sherwood RX-4105 Receiver
Error 71 an the reciever shuts down
You have a speaker short. Disconnect all speaker wires at the receiver, then turn it back on to test. If you don't get the error code, your receiver is still ok. Reconnect your speaker wires one by one and test the power on the receiver until you find the wire that's causing the problem. Then disconnect that wire at the speaker and test again, this will determine if you have a bad wire or a bad speaker. If the receiver still reads error without speakers attatched, you will need to send it for service. While it's at service, check all wires and speakers for shorts with a meter if you can. This is the most common failure of all receivers, a shorted wire. Hope this helps
Sep 26, 2009 | Pioneer VSX-D711 Receiver
Kenwood dnx7100 in protect mode
Your receiver is detecting a problem in the speaker wiring and is going into protection mode. If the receiver shuts off due to volume level, this can be caused by a poor connection, damaged speaker, insufficient gauge wire, or connecting multiple speakers to one speaker output. The connections at the receiver and speaker should be clean with the ends of the wire twisted tightly, preventing any strands from missing the terminal. Connecting two sets of wires together to add distance should be done with terminals and insulated to prevent the wires from touching each other. If using thin wire, replace completely with heavier gauge wire; do not add to the existing length. Be careful not to push the speaker wires in too far, this will cause the speaker terminals to grip the insulation and not the conductor. The speakers being used must have an impedance within the range listed next to the receiver’s speaker outputs, normally between 6? - 16?. The impedance of your speaker should be listed behind the speaker itself.
If problems continue, disconnect the speaker wires from behind the receiver and power the receiver on. The receiver will shut off quickly if there is an internal short and would need to be serviced if this happens. If it stays on, try connecting the speakers one at a time. Replace any speaker that causes the receiver to shut off.
Thanks.
Jun 24, 2009 | Kenwood DNX7100 Car Video Player
Whenever a little bass sound - explosions, gunfire, helicopter blades, etc., ''PROTECTOR'' flashes on LED and shuts down receiver. Seems to happen more frequently lately. Subwoofer cable sturdy, no...
The protection feature on these units will shut off the receiver when there is too much power draw or when a speaker wire is touching another wire. First, check all of your speaker connections and make sure the wires are nicely twisted and inserted into the speaker and receiver with no stray wires touching. Secondly, if this doesn't correct the problem, try going into your speaker settings menu on your receiver and select "small" for each speaker. Let your sub handle the bass. The sub cable should have no effect on the protection feature of the receiver. The speaker wires, however, are the most common culprit of a receiver turning off (protector). Hope this helps.
May 03, 2009 | Sony Televison & Video
Sherwood RX-4105 Receiver Logo
63 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
