Question about Zanussi ZWD12270 Front Load Washer / Dryer
I have a zwd12270w. Seven second after pressing
I have a zwd12270w. Seven seconds after pressing the cycle start button, the machine double clicks and stops.
If I press the start button after seven seconds, the machine does not respond to the start button.
The above happens whichever cycle is selected.
  • 7 Answers
The problem is with the tumble drier heating element. If you remove the top of the machine (disconnect it from the electricity supply first!) you will find a big metal oblong "bar" that runs from the front to the rear of the machine. At the rear there are 4 white wires connected to the metal "bar". Make a note of where they go and remove them. You may need pliers to get a good grip of them. Once removed, the washing machine should work just fine but obviously the tumble drier will not. This is a well known fault and it may be worth contacting Zanussi as they MUST know about it!
Posted on Jul 26, 2011
  • 3 more comments
  • CrazyLady01 Aug 14, 2011
    Had the same problem today followed the above advice an washing machine is working great. Thanks
  • demianneca Aug 19, 2011
    Had same problem and followed advice above and... it worked!!!! Now machine is working as it should be. Thanks a lot, mate!
  • Jedza Jan 23, 2012
    U a great . People like make the world go round xx
  • nicolaretter
    nicolaretter Mar 13, 2012
    had the same problem also. Followed the exact advice. the wires slide off with a pair of pliers and can be easily put back on if not the answer. But it was. Am literally dancing round the kitchen that I have fixed it. thank you so much.
  • Dave Waters Jan 02, 2013
    The advice was spot on and got my machine goimg again but how do i fix it so i can have full use of the machine ?
I just had the same problem, could tell me where is the dryer plug please? i'll try to disconnect and see what's happen. thanks
Posted on Feb 14, 2011
This has happened to me too, several times infact, very frustrating when u have to wash a number of washes, i had a basic idesit washing machine for years and had not 1 problem, agree with the solution above,- If left alone for a day or 2, then problem solves itself, good luck!
Posted on May 05, 2010
Had this problem and i can confirm a problem with dryer, we had seperate tumble dryer as well as washer dryer, so the engineer just disconnected the dryer part and washes fine! was an electrical fault from dryer!
Posted on May 03, 2010
I have no solution as such. Mine does the same. It has happened twice now following long use of the dryer function.
Both times, the problem has solved itself after a day or so being left. I cannot work out at all why this would be, but it certainly seems to be linked to the use of the dryer.
Posted on Aug 23, 2009
The orange on/off button lights up. however the start/pause button does not.
It's hard to tell by the way you've phrased the question whether or not the button is doing what it is supposed to do, or if it is just the light indicator that is not working. So, I will answer both scenarios. // Press start button fully until you hear machine start; (usually less than one full second). In other words, hold button in until ''start'' is _heard_. After start has begun, holding button for 3 full seconds will ''pause'' the cycle. After ''pause'' pressing button again (just like first time) will restart cycle (i.e. ''take it off pause''). But while ''paused'' holding the button in again for any longer than a fraction of a second will cancel the wash. // TO CLARIFY: Press button for approx 1 second to start wash. After start has begun, pressing button for 3 seconds will ''pause'' wash. While ''paused'' pressing button again for less than a second (i.e. ''quick press of button'') will ''resume'' wash. Also, while ''paused'', pressing button for longer than a second (usually 3 seconds) will cancel the wash. // If the machine is (otherwise) working correctly, and your complaint is a light not lighting, then it is just a bad LED light. Best bet is leave it alone. Or, you could buy a new switch if the LED is _inside_ the switch. If the LED is on the control panel, then do yourself and big favor and don't mess with it.
Aug 15, 2015 | Washing Machines
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 30, 2012 | Maytag Washing Machines
Power to machine but will not start a cycle
If child lock has been activated, all buttons on the control panel except for the power button will be inoperable. Child lock is usually activated by pressing either the [pre-wash] or [tub clean] button for 3 seconds. To deactivate the child lock function, press and hold the same key again for 3 seconds.
Try switching the machine off by pressing the on/off button. Press the same button after a few seconds to restart the machine.
Mercedes Parts
May 25, 2012 | Washing Machines
Control locked, how do I unlock it. I can't start the washing cycle.
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
OR press options and select for 10 secs till LOC is no longer displayed
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 03, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
What to do when washer is locked on control locked?
OR
OR
OR
Unplug washer
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Says control locked
OR
OR
OR
Unplug washer
Feb 14, 2011 | Washing Machines
My washer won't start, it keeps flashing ERR and then the wash-time, and then LOC. My roommate says to fix it before, he held down three buttons, but can't remember which ones. Any idea?
Try the following two buttons: press Options and Select together for 10 seconds (or until the LOC disappears). The pair of buttons held for 10 seconds also sets this control lock.
To find out the error code, turn the Program knob to the start position, Spin Only. Press Start/Pause to start the cycle. Press Cancel to stop the cycle and turn off the LEDs. Press Cancel again and within 5 seconds press and hold the Options and Start/Pause buttons until the LEDs start chasing. Then release the buttons. Turn the Program knob seven clicks clockwise from the Start position. The control will signal the last error code. To clear the error, press and hold Options and Start/Pause for 3 seconds. Then either unplug the washer for 5-8 seconds before plugging it back in. Alternatively, press and hold Options and Start/Pause together for a few seconds until the Wash LEDs appear.
http://www.applianceblog.com/mainforums/frigidaire-electrolux/12950-frigidaire-atf6000es1-wont-drain.html has a link to the service manual for the listed washer (the link is half-way down the page).
I hope this helps.
Oct 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Control locked light is on
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
Zanussi ZWD12270 Front Load Washer / Dryer Logo
1,132 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
