Question about Acer AL2016W 20" LCD Monitor
Images are too long horizionaly and short in height on this ACER AL 2016 WB monitor. Can it be adjusted?. Windows XP.
  • 413 Answers
Have a look on the Monitor setup disk.
Somewhere on that disk you will find an instruction manual, this will tell you how to adjust your screen...
Posted on Jun 28, 2009
Black Screen - No image at all
Has to be a short some where in the monitor.
Mar 07, 2014 | Acer V193w LCD Monitor
My Acer 22" wide screen
change the resolution on the pc to 1024 x 1024 and then increase one size bigger each time till you find the correct one. Click start > control Panel > display settings then click settings change it in there (XP)
Apr 17, 2011 | Acer Computers & Internet
I have an Acer AL 1914 Monitor. Green light
Check power supply section for bad caps first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 26, 2010 | Acer AL1914 19" LCD Monitor
How do i adjust the height of my monitor?
Hey mate to change the height of the image, there shoul be buttens on the monitor one saying menu or something like that... the height settings are in the menu its self
Apr 13, 2010 | Computers & Internet
How do I get a normal image on an Acer X203H monitor?
right click on your desktop and select "properties" (xp)  or "personalization" (vista/7).  In xp, select the "settings" tab, and in vista/7, select "display settings". then adjust your screen resolution to a wider aspect ratio to compensate for the wide screen.
Dec 26, 2009 | Computers & Internet
Possible to install Windows XP on an Acer 5532?
Yes you could but Acer won't support it. You either have Vista or 7 in it. If Vista, update to 7 and be done with it.
If you want XP, first copy a full image of your present OS on a external drive using a program like Acronis True Image Home. Then reformat your hard drive when doing an XP install. Do you have a full version XP install disk?
Dec 19, 2009 | Computers & Internet
Screen monitor images on the righ side is not showig.
Hi afcarrillo,
This could be a simple resolution problem. By that I mean that the resolution is set too low, therefore putting things off screen. Here's how you change the resolution:
Windows XP
Right click the Desktop and select Properties. Click the tab all the way on the right that says settings, and drag the slider to your native resolution of 1600x900
Windows Vista
Click Start, Control Panel, Appearance and Personalization, Personalization, Display Settings and drag the slider to 1600x900
Windows 7
Simply right click the desktop, select Screen resolution and pick 1600x900
If you do not have a resolution problem, then it's most likely the monitor itself. Most often times you can fix it one of two ways:
1. Some monitors have a button that says "Auto" which will auto adjust your monitor. If you have one, try it.
2. If that didn't work or you don't have one, go through the monitor's OSD (on screen display) and work through the settings so that you can manually adjust it and set it to your taste.
Hope this helps :)
Nov 29, 2009 | Acer Computers & Internet
Just bought Acer X203H. Hooked it up to windows Xp 2003.I make greeting cards with Print Shop 12 The cards or out of shape. They are to long horizonally and to short vertically when I am trying to design...
This is because your screen is widescreen and it is hard to get the dimensions right because when you look at the monitor, the aspect ratio is unusual. You would have to manually adjust your monitor settings (using the buttons on the side of the monitor) to make it look like a normal screen.
Nov 06, 2009 | Acer X203H bd Monitor
Monitor squeezes images toward bottom of open software windows.
Un install the video driver and reinstall also check if any update is available for the same.
Let me know.
Jan 13, 2009 | Computers & Internet
Double Images / Shadows on the monitor screen
Hi..there,
Have you guys...try to open your OSD on your monitor and blanced the colors or adjust the WB (white blanced) settings....
Jun 30, 2008 | Gateway FPD2275W LCD Monitor
Acer AL2016W 20" LCD Monitor Logo
210 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
