Question about Dell Dimension E310 PC Desktop
IDE disk failure
I was installing windows xp on an old computer, HD 80Gb, at the end of the formating process crashed, now I have an IDE disk failure and cannot start the computer
  • 255 Answers
1. reformat it again
2. while installing windows xp, you should format it in Fat(32) full format
3. dont format as quick format
4. try it
Posted on Jun 28, 2009
RM Z91FR laptop I want to remove the windows "Vista Ultimate" operating system and go back to XP Vista has slowed the machine drastically and filled the HD. I also want to instal a larger HD...
try to format all your drive by deleting your partition..insert your xp cd room boot with cd room press enter, press f8 press esc, press d, press l, then press c and enter
May 06, 2011 | ASUS Computers & Internet
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
SMART failure predicted on hard disk 0:
There is a big problem with newer conponents and Win XP versions prior to SP2. Especially with newer motherboards.
You have to make a bootable SP2 disk if you don't already have one. To do this use the slipstream proceedure specified on the Ms website. Many other websites describe the process with easier language.
Slipstreaming is a common practice now. Essentially, you copy your original install disk to the c: drive then download SP2 to C: drive then download the slipstream utility from MS. Running the slipstream utility then inserts the proper drivers (ide and HD drivers too) into the licensed copy you have. You then create a bootable disk from the slipstreamed files you have.
This approach is resolving alot of blue STOP errors and SMART errors.
ALSO, you want to make sure you are installing any drivers provided by the MB manufacturer AND Drive maker.
Good Luck
Jul 29, 2009 | Computers & Internet
No iede found
is the hard drive showing in bios? you may have a hd too large for the bios to read. has it been fdisked or formatted?how large was the od hd? was it the same type hd? either way when you reload the operating system you will need a disk. post back and let me know, i will try and help. just the info you gave is not enough to attempt repair.
Jul 19, 2009 | Compaq Presario R3000 Notebook
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
2 hard disks
Because you have a dual boot system, you have two 'C' drives, which in fact is a good idea if you get a system failure on the drive you are using, you can select the other and still view any files on the other drive through my computer.
f using XP, right click my computer, then properties, then click advanced tab, then startup and recovery listing click settings, at the top system startup, select the default operating system, then click EDIT button, then delete the value that points to the other hard drive more than likely listed as disc1, disk 0 will be the one you have connected as master boot hard drive
Aug 29, 2008 | Microsoft Windows XP Professional With...
Istalling windows
Bought a Nikkai A52HF digital reciever&recorder from Maplin. Installed 80Gb IDE HDD (tried it formatted in 3 different ways). Whereas it orks fine as reciever without the disc, with the disk it...
format it from the menu on the PVR the default code for the Nakkai is 888888 but the file format for the hard drive is probably UDF or some other format that windows cannot recognise or reproduce.... i think lol
Jul 12, 2008 | Televison & Video
Compaq d540s hard disk upgrade
Jackwan -
Sounds like the boot record of the drive may be corrupt. When you runs the XP installation, you'll be given an option to start the Recovery Console. Go ahead and open that, should bring up a command prompt. At the prompt, type "fix mbr" (With the quotes removed). Select Yes or Continue when asked, and go through the repair process, then reboot the system and try installing Windows again.
*Note*
You might want to check first, make sure the jumpers on the hard drive are set to Master, or Cable Select, and make sure the drive is connected as Drive 0 on the Primary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | HP Compaq d530S PC Desktop
Would a SCSI disk and a IDE disk work together?
This solution works on WIN98 and I don?t see a reason why it wont work on you If there is something that you were missing you might want to check with anther expert. This solution is a little complex so I hope ill be able to explain it well enough: 1. Make a boot disk so u can format and install windows. 2. Define the new HD as MASTER and hook it up to "primary IDE" 3. Disconnect the SCSI and pull the board out. 4. Reset the comp from the boot disk u made (HD is connected) 5. Get in "bios settings" and make sure that the new HD is defined as "primary drive" In the 1st IDE 6. Now, perform a FDisk on the new HD, define partitions, do a reset and format the HD Install the operating system you wish to have, make sure it works well. 7. install the SCSI board and its HD make anther reset. 8. now the comp is supposed to make boot and recognize the SCSI, it is possible that you will need to define your system configurations but for that, regretfully, I cannot guide you Although this is not necessarily have to happen. Good luck
Feb 23, 2006 | Cybertron Intel Pentium 4 2.66GHz Serial...
Dell Dimension E310 PC Desktop Logo
99 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
