Question about Sony PlayStation 2 (PS2) Console
My playstation wont turn on
I can flick the switch at the back and have all the cables plugged in, but the red light won't come on
  • 4 Answers
Try other electric slots....maybe the wire is not working .....try borrowing a wire from someone...!!!
Posted on Jun 28, 2009
My PS3 was working fine, its the original PS3 model when it first came out in 2007. Was playing black ops, then it just froze, so i switched it off. Switched it back on, flicked to HDMI channel - nothing....
One of the biggest causes of the blinking red light problem is placing the console with the fan vents sitting against the floor or up against a wall where air cannot flow freely in and out of the console.and to fix PS3 red light blinking is to unplug the console from the wall for about half an hour and then plug it back in. This doesn't always work, but some people have had success with problems other than overheating...
better u download repair guide
click here to download repair guide
Dec 16, 2010 | Sony Playstation 3 (PS3) Console
When entering a game I hear sound but no picture. Plugged in correctly and TV set to HDM11.
If you are sure that you have your TV on the correct input, you can try resetting the PS3's video settings using the following procedure:
  1. Before changing cables, make sure the PlayStation 3 is turned off using the main power switch on the back of the PlayStation 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PlayStation 3 and television (or display) from the wall socket.
  3. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PlayStation 3 system.
  4. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  5. Plug the PlayStation 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PlayStation 3 back on (the line on the power button is now pressed).
  7. While the PlayStation 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PlayStation 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
If that does not resolve your issue, try the other steps here:
http://us.playstation.com/support/answer/index.htm?a_id=262
Oct 25, 2010 | Sony Playstation 3 (PS3) Console
Tv and ps3 plugged in and on. av channel shows an empty screen
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont display on the tv!!
Jun 10, 2010 | Sony PlayStation 3 40GB System
My Xbox 360 has sound, but no picture and no red lights
This may be something to do with the AV cable, because there is a switch at the bottom on it (the end connecting to the console) and it has a switch which changes from TV to HDTV and svise sversa so what i suggest is flicking the switch up or down and turn the console on then back on hope fuly this helps you
Nov 25, 2009 | Microsoft Xbox 360 Console
Ps3 broken
When you attach your Play Station 3 to an HD TV through an HDMI port, the Play Station 3 will ask you if you wish to switch to HD Mode.
However, if you decide to move it to another TV that is not HD compatible, you will get no picture because the Play Station 3 is “stuck” in HD (HDMI) mode.
That’s it! You can play your Play Station 3 again!
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
While on vacation switched to 1080 now home and have regular tv now cant see to get back to regular. Im to the far right of menue. Need to know many to go right, down, button to hit to enter and then how...
Try resetting the video output. Follow the steps below:
  1. Before changing cables, make sure the PLAYSTATION 3 is turned off using the main power switch on the back of the PLAYSTATION 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PLAYSTATION 3 and television (or display) from the wall socket.
  3. Make sure the AVI cable is connected to the [AVI OUT] port on the back of the PLAYSTATION 3 system.
  4. Connect the other end of the AVI cable into the [AVI Input] port of the TV or display monitor.
  5. Plug the PLAYSTATION 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PLAYSTATION 3 back on (the line on the power button is now pressed).
  7. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Thank you for using fixya!
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Playstation3 wont turn on red flashing light then a double beep then turn off
Unplug the power cable from the back of the PS3, wait around 30 minutes...this will allow the unit to cool down. Plug the cable back in and try to boot the unit again. If you still have a red light, call PlayStation. If you're still under warranty, they'll send you a new unit at no cost to you. The problem may be the Hard Disk. This happened to me and PlayStation was very easy to deal with.
Jul 06, 2009 | Sony PlayStation® 3 (80GB) Console
Sony PlayStation 2 (PS2) Console Logo
62 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
