Question about LG Vu CU920 Cellular Phone
Blue circle around bottom menu buttons when pushed
I recently started having a blue circle around my bottom menu buttons and also a few other menu options when pushed. What does this mean? Can I stop this blue circle?
Haha, that is normal :) that happens when you press anything to show you what you have pressed :) and im sorry no, its how the phone was made.
Posted on Jun 28, 2009
Why is it stuck on the reboot screen?
reset it somewhere to push a few buttons together by reboot or start this will maybe the tablet goes booting in a bios factory mode with Chinese symbols like a Polaroid smartphone.
Mar 06, 2016 | Ematic 7" Touch Screen Tablet
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
If the following doesn't work the tubes could be at the end of life:
Adjusting convergence:
Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
  1. Press the 'MENU/SELECT' button on the remote.
  2. Press CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
  5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
  6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
  7. Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
To Adjust multipoint convergence:
  2. Use CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
  5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
  6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
  7. Press the 'EXIT' button to enter ADJUST mode.
  8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
  9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
  10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
  11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
  12. Press CURSOR RIGHT to save the multipoint settings.
  13. Press the 'EXIT' button to exit the menu.
Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
Blue circles on images forehead, cheeks and chin.
Try cleaning the contacts on the connectors going into and out of the Tcon board, if that doesn't fix it replace the board, here is the manual if that helps.
Samsung HL S4266W Owner Instructions Manual
Jan 06, 2018 | Televison & Video
Pc no starting up properly
Have you considered starting up in safe mode and restoring to a previous date?
Jan 11, 2009 | Dell Dimension 3000 PC Desktop
Roomba just runs in small circles
i just recently had someone bring in a roomba discovery and all it would do is stay in a tight 4 tile area and go in circles. battery was fully charged and all bumpers were clear.
i took a can of air blast for cleaning computers and blasted the area on the bottom underneath the sensor and watched as several dust bunnies came flying out.gave it a few more blasts for good measure and put it back on the floor and hit power then clean buttons.
thing went in same tight circle for 2 passes then the circle got bigger for 2 more passes , blue light indicator came on and it made a straight line dash across to closed door and started following the edge and criss-crossing the room.
called the owner back in to test and it repeated the same moves when she started it and all appeared to be working normal again.
Aug 13, 2008 | iRobot Vacuums
Sansa e260 takes 15 mins turning on.
once the blue circle is there, you just need to wait, it'll turn on
if not, take it to a best buy
May 05, 2008 | SanDisk Sansa e260 MP3 Player
H700 Headset
Is the Samsung bluetooth turned on?
Jul 17, 2007 | Motorola Mobility H700 Wireless Headset
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
LG Vu CU920 Cellular Phone Logo
94 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
