Question about Compaq Armada E500 Notebook
Laptop not getting ON
I didnt use my laptop for more than one and half year...now its not getting ON...what to do ...I connected to power supply also
  • 255 Answers
1. check your charger, is it working
2. when you switch on your laptop, there should be some lights on in your laptop
3. if no light are no signal, then check with your charger..
Posted on Jun 28, 2009
    Sergeant:
    Champion:
  • 233 Answers
The issue could be due to various reasons.
I recommend you to follow the steps in the below link:
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Folllow the steps from No power or no boot
Also visit the below link for more information:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=96231&prodTypeId=321957&prodSeriesId=96231&objectID=c00372748
I am getting nothing but a green light on my motherboard when I plug the power supply half way in to the motherboard the fan and processor start running but when I plug it all the way in it stops and...
I would need to know what all you are trying to run in your computer to offer much assistance, but hot plugging power cords in computers is a good way to fry the motherboard. It sounds like you don't have a big enough power supply for everything you are trying to power, so that when you connect enough of the power plugs, the supply shuts down from trying to draw to much current.
If you post your hardware specs, I will try to offer more assistance.
Thanks,
John Vickers
Aug 12, 2011 | ASUS P4P800-VM Motherboard
My acer aspire one mini laptop won't turn on when i charge it. the orange light does'nt come on and i last used it about a week ago,and it hibernated because of low battery. iv'e had my laptop for about...
Remove the main battery and power supply charger adapter from the laptop, wait a few minute to get rid of any residual charge, now install the battery, power up! if no change remove battery, next plug the power supply back in, power on, if yes! the main battery is bad and needs replacement. If no change reply to this message so I can help you further. If you having low memory issues, the ram needs to be upgraded.
Jan 12, 2011 | Acer Aspire One Netbook 8.9" Notebook
This is my system, -K10N780SLIX3 wifi Mobo -Gtx 260 Evga card -amd phenom II X4 3.4Ghz -6gb ram -1tb WD sata HDD -1000watt power supply. And I can not get a display anymore but it starts up fine, no beep...
swapping out parts, try with different power supply pull the ram reseat it maybe one at time. different memory slots. change one part at a time with good working part, never assume any part is good.
Apr 18, 2017 | Asrock Computers & Internet
Acer Extensa 5620: The power supply jack is loose when you plug it into the laptop. Sometimes it will provide power and sometimes it will not (orange battery light on front of laptop goes on & off)....
System check
1. estimate the extent of damage, possibly requires entire board replacement housing the extension power supply modulators, possibly due to physical damage on contact.
2. Aslo check the battery life since could determine the possibilty of substituting power chord from currrent outlets with batteries
The device would not connect to power outlet without a properly functioning battery installed. A depleted battery could not be replaceble by connecting a source out power outlet. each parts of the power complement the entire process of achieving computer experiece.
Consult a technician insisting the replace the entire power system of battery and ac adapters and also fixing damages on the mother board may be contributing to power leakage
Dec 02, 2010 | Acer Extensa 5620 Notebook PC
Hot laptop and battery charger
It may well be that the battery that's being charged is getting past its sell by date. They only last for so many charges. easy way to find out is remove the battery, connect the power supply, and if the charger power supply doesn't get hot (usual to get warm) then its your battery. It is perfectly okay to use the laptop without the battery installed on the mains.
Jul 15, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
My dell 1525 no power at all
Good luck with this colossal piece of junk from Dell. I had the same problem. Second Inspiron to do this. I ordered a new battery. The Dell techie was SO impressed that the battery lasted more than a year. It lasted a year and a half. Anyhow, new battery arrives, and it won't charge. They tell me it is probably the plug in and the motherboard. Nothing like spending over 500 to fix a computer that I paid 600 for that did not even live to see two years old. Did I mention that I will NEVER buy another Dell.
May 26, 2010 | Dell Inspiron 1525 Laptop
My power won't turn on. The battery and the cable
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Oct 07, 2009 | Acer Aspire 3680 Laptop
Toshiba Laptop not Taking Charge
ya the solder connection connecting the ac power input onto the transformer is probably weak. aside from taking the case apart and resoldering the connection, not much else you can do.
Jun 18, 2009 | Computers & Internet
HP Pavilion dv2020us laptop battery won't charge
How is your power supply? does it seem like you have to wiggle your cord that connects to computer to make it recieve power?...Many laptops power supply become loose over time form moving the cord around..when it does, the battery has a hard time getting electric power to recharge. Also, you my have other problems with your lithium internal battery that powers your cmos.
Check to see if your power supply is loose and go from there. the power supply is the little hole where you connect the cord to the laptop.
let me know what the status is
Apr 10, 2009 | HP Pavilion dv6000z Notebook
Problem with battery or motherrboard?
ok..first thing..does it run ok with no battery on mains power?
Feb 29, 2008 | Acer Aspire 5100 Notebook
Compaq Armada E500 Notebook Logo
222 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
