Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Where do you buy the balance switch from
I have the same problem. My balance switch is actually broken and I need to purchase a new one. Where can they be bought from?
  • 3 Answers
F&p morningside brisbane
Posted on Jul 28, 2009
I think the switch on my petrol cutter is broken how do I replace the switch on my makita cutter
Dismantle the unit, taking photographs as you go and verify that the switch is actually broken (electrically or mechanically). Gain the make and model number of the switch and purchase a new one. Online is probably cheaper. Refitting is the reversal of the dismantle. Cheers Bob
Oct 16, 2016 | Makita Saws
Dyer wont stop when door opened
there is a switch on the door this would be my first place to check the mechanism that pushes on the switch may be broken and locking the actual switch in the closed position or the switch itself. this should be a simple fix. you may be able to bend mechanism back into correct shape or you may need to buy a new switch to replace the one on door
Sep 15, 2014 | Whirlpool Dryers
Where can I buy New Balance 4E 645 #MW645BR
If new balance doesn't have them, you arecout of luck.
Apr 19, 2013 | New Balance 645 Shoes
Broken yoke can this be replaced or must you buy a new driveline
You could have a new yoke welded on. Then you would have to have the driveline balanced. It would probably be just as cost effective to purchase a new one.
Mar 14, 2011 | GMC Sierra 2500HD Cars & Trucks
On-off switch does not function
As in power switch? I don't think they make power switch replacements, you may need to either send it back to Dell (if it's still under warranty), or purchase a new monitor.
Jul 28, 2010 | Dell E207WFP LCD Monitor
A Wii remote control hit the screen and now it looks like a spider web when I turn it on. Where can I purchase a new screen?
Sorry, but forget it. Unfortunately you've broken the single most expensive component part of your tv. Buying the screen separately often costs more than replacing the tv and that's before you add labour charges as fitting it is not a DIY job.
In essence, when you buy the tv you actually buy a the screen at a bulk discount with all the other parts needed to make it a tv thrown in free of charge.
Your only realistic fix is to buy a new tv, sorry.
May 12, 2010 | Philips Magnavox 42MF521D/37 Television
Engine board burned out. plugged the 120 into a 220 volt. need to replace the board. do they sell this part or is it best to buy a new one?
You purchase the parts from Treadmill Doctor as the company no longer makes treadmills call them Toll Free Phone: (888) 362-1105 or www.treadmilldoctor.com
May 05, 2010 | New Balance Balance 1500 Treadmill
The light switch is broken and the fan wobbles like mad at high speed.
The wobbling is most likely caused from the blades being out of balance. This could be from something striking the blades while it was spinning, from an accumulation of dust on the top of the blades or from one of the nuts and bolts used to attach the blades to the brackets falling out. To re-balance them first clean them thoroughly and replace any missing hardware. Then using a step ladder get at eye level with the blades and spin them by hand.You are watching for two things. The first thing is the angle of the blades. The second is the height of the blades. Locate any that are misaligned with the others and mark them with a piece of tape. To realign a blade find a hand hold on the body of the light\fan below the blades with one hand and with the other, grab the blade close to the end attached to the metal bracket and gently bend it back in alignment. You don't have to use a lot of force to bend and\or twist it. Just use trial and error until it looks right. Now turn the fan on and check your progress. It may take a couple tries to get it right.
As for the switch......Are you referring to a broken chain pull or the actual internal switch. If it's the internal switch then it is possible to replace it however it would require the unit to be taken down off the ceiling to get at the interior. A new switch can be purchased at most hardware stores. But you will need to have the old one for comparison.
Hope this helps.
Sep 06, 2009 | Hampton Bay Dryers
Fan appears to be out of balance
There should have been a small lead weight kit that came with your fan. First check to make sure all the screws are on tight and clean the blades from any dust buildup. Make sure your blades aren't warped. If they are, you cannot balance your blades and will need to buy new ones. See if that helps. If you don't have the lead kit you may be able to buy one at your hardware store. You can also measure the end of the blades to the ceiling to see if one is warped or heavier than the others. You can also remove the blades to see if it's the actual motor assembly that is out of balance.
Jul 01, 2009 | Hunter 23258 The Paramount XP New Bronze...
Concrete counterbalance broken (Frigidaire FWT449GFS1)
Check with a company online called sundberg appliance parts, the counterbalance isn't hard to install and will definately be cheaper than new one.
Apr 23, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washing Machines Logo
83 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
