Question about Fisher and Paykel GWL11 Top Load Washer
Removing heating element from a hotpoint WML 940 wash machine
How do i remove the drum from a Hotpoint Aquarius WML 560 P
There is not much you can do to remove the drum of your WML 560 P Washing Machine...you can remove the bearings and door but you can't remove the drum personally. You'll have to take it in for service but here is a manual for you which you can read through to see if there is anything about removing the drum. Click on the link below to be directed to your Hotpoint Aquarius WML 560 P User Manual homepage...
Hotpoint WML 560 Instructions For Use Manual
Aug 26, 2014 | Washing Machines
How to remove the detergent dispenser drawer aquarius WML 520
Instructions for the machine, and specifically the detergent dispenser drawer, are here:
http://www.manualslib.com/manual/70853/Hotpoint-Wml-520.html?page=10#manual
It does NOT show how to remove the drawer. It is likely that the top of the machine must be "popped off" to do so. The best advise is to search for a Repair Manual if you simply must get the drawer out. I believe one of the manuals shown on this webpage may be the repair manual:
http://www.index-of-pdfs.com/hotpoint-aquarius-wml-520-user-guide-pdf.html
Most washing machine tops are simply a pressure fit that snaps on to the body. A firm grasp on the front sides of the top and a brisk pull may well pop it off.
Be sure to unplug the machine before you attempt any service!
Washing machines can be full of water AND electricity. That is most certainly a recipe for one, big, hydro-electric
Aug 04, 2014 | Washing Machines
I would like a washing machine manual
go to the makers internet site, type in for manuals your machine
Jul 27, 2014 | Hotpoint Washing Machines
My hotpoint wml 720 taking hours to wash whats wrong
If the cycle time is extended this could be due to the unit not heating (element or stat) or not pumping out sufficiently to let the pressure switch drop out ready to refill for the rinses or there is a significant drop in water pressure or tap not fully on and the machine is taking too long to fill up after each drain of the w/m.
Hope this gives you a starting point, good luck.
Jul 11, 2010 | Hotpoint Washing Machines
Hotpoint aquarius wm63
The heating element for this paticular model is located on the front casing of the drum.. you have to remove the front panel complet with the door and you will see it at the bottom behind a black protective cover.
Nov 27, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washer dryer not heating up
both the 'wash' & the 'dryer' have their own heating elements, If the 'wash' completes its full cycle including 'spin', then I suspect this heat element is ok.Re the dryer, most likely the heat element circuit is 'open circuit' somewhere, could be  the element, thermal fuse, thermostat, or a wire burned out
Oct 23, 2007 | Hotpoint Aquarius WD640 Front Load...
Fisher and Paykel GWL11 Top Load Washer Logo
29 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
