Question about Acer Aspire 5100-5022 Notebook
When pressing the power button, the Acer Aspire 5022 beeps numerous times and nothing shows up on the LCD.
  • 255 Answers
1.this is ram problem
2.remove your ram, clean it and fixt it
3. otherwise buy a new ram and fix it
Posted on Jun 28, 2009
Acer Aspire 7720-6155 wont boot
put cd in dvd writer then open the laptop and press f8 and after that if lap asked for esc/ or for enter press esc then it will work .
Sep 12, 2013 | Acer ASPIRE 7720-6155 LAPTOP LCD SCREEN...
My acer aspire laptop makes a beep sound when swith on button is pressed
beep are of manyh types how many beeps it gives?????? reply me fast so that i can help u
Jul 06, 2012 | Acer Computers & Internet
Still showing code 88. We unplugged the Intex pump numerous time for more than 10 mins. After umplugging the unit several times for more than 10 mins. we powered the unit back up. We held the down button...
Okay!!! Kind of tricky sometimes.. After pressing the down button and you hear the first beep, quickly release the down button.. Now press and hold the up button until you hear the beep again and quickly release..The LCD should be blinking now and ready to set you time by pressing the up button...
If this does not work, you may have to call INTEX
Here's their info and I hope I helped.. Please rate me if I was helpful. Good luck...
Jul 23, 2011 | Intex Automatic Salt Water System for ...
My acer aspire bl51 doesnt open up at all, the power turns on , but there is a black screen what can I do to remedy this?
Hi liquidblue7,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 12, 2011 | Acer Aspire 5100-5022 Notebook
Acer Aspire 1800 Won't boot
I recently had Acer Aspire One Laptop with very similar symptoms: No screen, no lights (those that indicates activities) except Power button. I first thought the Hard Disk is dead but it's not.
I contacted Acer helpdesk in Australia and they have sent me a document with BIOS update and instructions. I did what it says and then the laptop is back to normal. Yours may have the same issue - need BIOS update. The Aspire One BIOS update requires a FAT USB drive with the updated BIOS and the BIOS Flash program, plugged it in, press and hold 2 buttons: Fn and Esc, then press Power button for a while.
You should seek Acer Support website. But you may need proof of purchase.
May 09, 2009 | Acer Aspire 1800 Notebook
Can see nothing on screen
press function and f5 at the same time
Mar 21, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 5100-5022 will not power up, power supply OK
maybe your computers battery is burned or maybe it's leaking
Dec 20, 2008 | Acer Aspire 5100 Notebook
Hinge Problem
Acer Aspire 3020 / 5020 Series Service Guide
Download it, extract it, open it, scroll to page 49-62 for disassembly.
Nov 29, 2008 | Acer Aspire 3050-1733 Notebook
Acer Aspire 3680 Laptop
hi,
1, make sure that your laptop got power. how to do it ? it is easy, the power led (close to headphone jack) is on. and power button led should be on. Just in case you can't power on, please check ac adapter and power port on your laptop.
2. i assume you have power. now power it on and press f2 to got to bios. press f2 many times, it should make a beeps when you press it many times. once you get a beeps, press fn+right arrow to adjust the brightness of lcd. did you see something ? what i am looking is dark display.
If your display is dark, open the power cover (power cover is cover where you see power button), you need to remove 2 screws on that cover, on lcd hinges. After you remove power cover, you can see cable close to power button, remove it and check the display again, is it bright or still dark, if it is still dark it could be inverter or lcd.
if your power is on and you press f2 many times, it doesn't make beeps sound. it is called no post. Reseat memory and if this still not working, your motherboard is bad. if you have 2 memory installed, try 1 by 1. sometime the memory slot is bad, sometime memory is bad.
i hope this troubleshoot will help you to find out whats wrong with your laptop.
good luck
Aug 23, 2008 | Acer Aspire 3680 Laptop
Laptop monitor goes black
Welcome to Vista. Windows Vista is automatically set up to power down after you have left it alone for too long. If you press the power button everything should be fine. Otherwise tell me what happens.
Dec 09, 2007 | Acer Aspire 5100-5022 Notebook
Acer Aspire 5100-5022 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
