We bought a 24,500BTU Air conditioner and we put it in yesterday. But, when it runs the water does not have a hole for the water to run out the back.Could you tell me why?
    Scholar:
  • 70 Answers
If it is slinging it on outside coil and not running back in on you it is normal. Evaporating the water helps cool refrigerant gas . AC units like this have a sling ring on fan. As hummidity drops in house there will be less water to sling.
Posted on Jun 28, 2009
Air Cools well but after about an hour, water starts coming into the coach through the discharge air side. Unit does not freeze up but if I shut the unit off, the tray that holds the water drains quickly,...
Your evaporator is probably dirty and is blocking some of the air flow so the air has to move around the coil and starts coming in through the condensate drain holes. That stops the condensation (water) from draining out the holes because the air is pushing it back in.Try having the unit cleaned and that should stop that leaking.
Jun 27, 2011 | Dometic Rooftop RV Air Conditioner
Yes, we have a fridgidaire FAC127S1A Model and we installed it today and are having trouble with it leaking water once it runs for a while. (The hole on the under side of the A/C.) Is this normal or is it...
If the water is leaking to the outside, that is normal. Especially if, the humidity is high outside.
If it's leaking to the inside. No, that's not normal and is due to improper installation. The rear of the unit should tilt down about 1/4" , to allow the water to drain outside via the drain pan hole.
To help you further, I have included a link to the Owner's Manual for your FAC127S1A model air conditioner. You can download and print it for future reference.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020213A0310en.pdf
Hope this helped you. Please let me know. Thanks.
Jun 13, 2011 | Frigidaire FAC127S1A Air Conditioner
Water Leaks inside of RV
When that happens it is because the drain hole up on the unit gets plugged with dust and dirt...you will need to take a wire up top and run it back through the hole to clean the dirt out of the hole so the water can get out.
heatman101
Aug 19, 2010 | Dometic Rooftop RV Air Conditioner
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
My GE air conditionar doesnt drain any water, I have it tilted whats the issue
Often dust and dirt will plug up the hole in the bottom pan...and keep the water from running out...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 18, 2010 | GE AJCQ08ACB Air Conditioner
Water is pooling in front of our M6X08F2A-C window air conditioner. We can't locate the drain to check if it is plugged. We installed fairly level, but think maybe the front should be higher - even if the...
We had the same problem with this very unit. There was no drain hole so I ended up drilling an 1/8" hole in a back corner where the water pooled the most. You may want to put some sort of rust protector on the bare metal in the newly drilled hole. Btw, you really should have the unit tilted slightly (about a 1/4") so the water runs to the back of the unit.
Jun 20, 2010 | Maytag M6Q10F2A Air Conditioner
My air conditioner is not producing any water
It will take a full season of runnig to produce a cup of water. Most moiisture evaporates and is exhausted out the hose.
May 31, 2010 | Kenwood KW85 Air Conditioner
Dometic air conditioner
1The air coditioner does run on Electric. 110V 2. No you do not have to unhook the battery 3. Yes you need to put water in the hot water heater so you do not burn the unit up.
Feb 01, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
