Question about Compaq Presario CQ60-212US Notebook
My computer will not power off when I click shutdown. Windows XP shuts down put the computer remains on until I press and hold the power button.
  • ozmanibt Jun 28, 2009
    Thanks, but that didn't help.
  • 255 Answers
1.disconnect your charger,after shutdown
2.hope your problem will solve
Posted on Jun 28, 2009
  • Mohammed Ehsanullah
    Mohammed Ehsanullah Jun 29, 2009
    download the link for Google desktop software...
    http://www.filehippo.com/download_google...
    install it, run it, there is a option shutdown, click it, immediately your system will shutdown.
    try it..
Acer extensa 4620z whe i shutdown laptop it's shutdown but the screen power still remains on untill i hold the power button to off , please help me
It seems that your computer needs to have a reinstall of your original setup, because the driver that tells it to shut down is not cooperating. Hopefully you have your original dvd/cd.
Nov 20, 2012 | Acer Extensa 4620 Notebook
How can i reboot my acer laptop
Press Start(ORB at bottom left for vista/w7) and if you're on windows 7/vista, there should be a list button on the bottom right side of the start menu saying "Shutdown"(windows 7) and "Sleep"(Vista), click the list and click Reboot.
On XP you need to click the Shutdown button and before you click shutdown instead click Reboot(Green button If i recall correctly).
Jul 15, 2011 | Computers & Internet
How do I shut off my computer? L670 series
Normal shutdown: Click on Start button (lower left corner on most PC screens), and then select shutdown.
Abnormal shutdown: If computer is "frozen" and you can't click on Start button, press and hold the power on/off button until the computer shuts down.
Jan 24, 2011 | Toshiba Computers & Internet
I can't shutdown my laptop
Hold the power button down for about five or six seconds, it will shut down then. If it keeps doing this, you need to look at what is running in the background that is preventing you from shutting down via the menu.
Click START
click RUN
type in msconfig
take a look at what is scheduled to load at startup and then try to decide if you really need to have that application on all of the time. BE CAREFUL. If you don't recognize an entry, leave it alone until you can learn what it is.
Rich
Dec 12, 2009 | Dell Inspiron 1525 Notebook
Windows will not turn computer off. I have unpluged every thing and all fans but the hard drive. I get 0.01 dcv when the computer is running and the same when I try to have windows turn the computer off....
This usually happens if Windows is having trouble closing a program. The easiest way to avoid the problem is to close all programs before you close Windows.
If that does not help, you need to track down which program is causing the problem.
If you are running Windows 95, remove all shortcuts from your StartUp folder.
If you are working with 98/ME/XP, uncheck all the programs listed in StartUp in the System Configuration Utility (you get to the utility by opening Start/Run and typing "msconfig" without the quotes in the Run box and then clicking on OK).
Shut down the PC. Reboot. Shut down again.
Then add one program back, shut down, reboot and shut down again.
If Windows shuts down as it should, add a program back to StartUp and repeat the shutdown, reboot, shutdown routine. Do that until you have pinpointed the errant program and reinstall it. If you are running a screen saver, consider it also to be a prime suspect.
Your Advanced Power Management, or APM, utility has decided to take leave of its senses.
Disable it, both in your BIOS file and in Windows.
That little sound riff that accompanies the shutdown is hitting a sour note.
Go to Control Panel and click on the Sounds icon to open the Property dialog box.
Scroll down in the Events box until you see Exit Windows. Change the sound settings to None.
Your TEMP folders are bulging at the seams.
If the C:\Windows\TEMP folder gets overloaded, all sorts of bizarre events can ensue. Clean it out. While you are at it, clean out your Temporary Internet Files folder as well.
Updating XP with the latest Service Pack may also cure the shutdown failure.
However, it is also possible that Advanced Power Management, or APM, is getting in the way of the shutdown routine.
APM may not be enabled in your XP configurations, but it may be turned on in your BIOS, a memory-resident program that controls how your PC sets itself up.
Microsoft recommends that you go to the Control Panel, click on “Performance and Maintenance,” and choose Power Options.
Click on the APM tab and click on Enable Advanced Power Management Support.
Personally, I don’t like automatic power management on desktops because it can cause all sorts of bizarre behavior. I would leave Advanced Power Management disabled in Windows and turn it off in the BIOS.
Consult your PCs manual to determine how to enter BIOS’ Setup file. Sometimes, as the PC boots, you can see a message on the screen that tells you which key to press to enter Setup. Press it before the screen welcoming you to Windows appears.
Once in Setup, look through the various sections until you find the option for controlling power management. Choose to turn it off.
For guidance on other XP shutdown problems, consult article 308029 in the Microsoft Knowledge Base. Use the article number as a search term at the support site below. Good information is also available at the aumha.org site.
Regards.
Aug 27, 2009 | Computers & Internet
Laptop locks up during shut down
fist of the click the start and click the run and type the recent and click.......ok and remove the all file in new windows
second method click the start and click the run and type the chkdsk and click.......ok
thard method click the start and click the run and type the temp and click.......ok remove the all file in new windows
Apr 01, 2009 | Dell Inspiron 1501 Laptop
How reboot my satallite pro laptop
To reboot a windows computer with Windows XP, click the Start button in the lower left corner, then click Shutdown, then Shutdown again in the popup box.
For a Windows Vista machine, click the windows Orb in the lower left corner, then the small arrow next to the lock on the bottom right of the start menu then click shutdown.
If you need to manually power off, hold the power button down for 5-10 seconds until the computer itself shuts off. This is only for when traditional methods do not work.
Jan 12, 2009 | Computers & Internet
How to rebot acer 4220 laptop
usually holding down the power button for a long time will force a reboot. I am not sure if that is what your asking
Dec 05, 2008 | Computers & Internet
I am 56 years old computers are not my generation. just got a new computer. and am trying to close it but it would not close . what I did is close the the monitor. and then pressed the button off of the...
You have to click the Start button and choose "Shut Down " and click the mouse on that. If that does not work, try pressing Ctrl + Alt+ delete simultaneously. What they call the task manager will come up. choose Shut down and click on it. It should shut down
Nov 08, 2008 | Acer Computers & Internet
Frozen laptop
According to the manual
Using Emergency Shutdown Procedures
If the notebook does not respond to the Windows shutdown
procedure (Start > Turn Off Computer > Turn Off), try the
following emergency shutdown procedures in the sequence
provided:
■ If the notebook is running Windows XP Professional: Press
ctrl+alt+delete. Select the Shut Down button, then select Shut
down from the drop down list.
■ Press and hold down the power button for at least 4 seconds.
■ Unplug the notebook from external power and remove the battery pack.
Apr 14, 2008 | Compaq Presario X1000 Notebook
Compaq Presario CQ60-212US Notebook Logo
65 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
