Question about Watches
The second hand of my swatch watch(Irony) is displaced. Does anyone know how to fix it?
3 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: Swatch Irony Aluminium instruction manual needed
hELLO THERE
please go to www.swatch.com and look for you brand and type there will be a online manual that you can use and download and print if needed ok?
best regards mike
Posted on Aug 05, 2009
mcdevito75
  • 1970 Answers
SOURCE: Swatch Irony Battery replacement will not work
mcdevito75 here, I am thinking your watch ran fine before the battery change. It sounds like the new battery is not makeing good enough contact, you can try, removeing the battery and cleaning the contacts in the watch carefully with a Q tip, dip the Q tip in anything containing alcohol cologne, rubbing alcohol, perfume wet the Q tip good, then sqeeze most out of the Q tip as not too saturate the battery contacts, also clean the battery itself, the oil on your fingers could give it a poor contact on the watch. The stop watch section doesn"t take as much battery power as the second hand. You may also be able to jump start your watch also, You"ll need a needle and a magnifier glass, With the back off your watch, right in the middle of the movement, just below where the stem (winder) goes, you"ll just see part of a little gear, this is the hour hand gear, see if you can gently move that gear just a fraction, place the needle between the teeth of the gear and try to move it as gentle as possible then se if the gear will move on it"s own., be very carefull with the movement. Swatch watches are collectables. If you don"t feel comfortable doing the above, look for a small watch repair shop in your area for help.
Posted on Jul 17, 2010
Hello, I have a Swatch Irony YCS514. Days ago I accidentally hit a solid surface with the watch and a button broke and fell. I am keeping the broken button and the spring in a safe place. Do you guys...
Swatch Irony are nice watches. And the suppliers usually have repairing agents. Take it where you bought it and see if they can fix it. Usually they can. If not, buy another one and be more careful. I've dropped lots of watches in my life and had to decide between repair or purchase a new one. I have a beautiful Fossil.
Nov 17, 2014 | Watches
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Swatch, irony, men's watch, doesn't work
the second hand, the small one at about 6 o'clock is moving which indicates your watch is working. the other large hand is not the second hand but the chronograph hand or stopwatch hand. You start it in motion by pushing the button a 2 o'clock. You also stop it this way. The button a 4 o'clock is the button than resets it to zero (12 o'clock). You didn't say what wasn't working. Does this help?
Oct 31, 2012 | Watches
How to remove the front glass of my swatch irony
remove the movement and press the glass out from the back. Not a job if you do not have the right tools. Suggest you send to a watch maker.
Feb 06, 2012 | Swatch Irony watch
I have a swatch irony chrono, but when I stop the stop-watch and push the bottom button, the sweep hand ends up at the 11 o'clock and not the 12 position. My quartz Parnis does this, and its driving me...
Assuming the mechanics work ok (thay all do 360 degree turns) it's just a calibration issue: download from SWATCH support a PDf which describes how to zero the watch hands, it's simple as taking the crown out to 3rd step, the pushing the buttons repectively till they point 12 direction. Exact details in the PDF.
Dec 11, 2010 | Swatch Irony Chrono #YOS414G Watch for Men
Suddenly its stops so i bought a new battery but still it wouldn't work even with a new battery
You are not in luck - Irony watches are not made to be serviceable and therefor you will have to send it back to Swatch or one of their dealers - hopefully it is under warranty.
Sep 20, 2010 | Swatch Irony watch
My Swatch Irony watch has recently been running slow. I thought it might be a low battery, but after a replacement, it still loses time (a few minutes each day). Any ideas?
Thank you for contacting Fixya,<br /> I would have the battery checked again. Sometimes batteries in stores can be past the extended life of battery. Otherwise could be a number of issues. Has it been around water? Dropped? Could need cleaning. In cases of most watches, like Swatch, the cost to have repaired may exceed the watch. <br /> You can contact Swatch at:<br /> <a href="http://www.swatch.com/zz_en/shop.html">http://www.swatch.com/zz_en/shop.html</a>
Aug 24, 2010 | Swatch Irony watch
Jul 17, 2010 | Swatch Irony watch
hELLO THERE
best regards mike
Aug 05, 2009 | Swatch Irony watch
I need to reset the hands
Assuming you want to reset the zero posistion of the chronometer (stop watch) hands...
On my watch I can adjust it by doing the following...
To reset the microseconds hand / top right
1) Pull the center knob full out (2 clicks)
2) Press the bottom push button to adjust the hand
To reset the seconds hand / middle
1) Pull the center knob a full out (2 clicks)
2) Press the top push button to adjust the hand
To reset the minutes hand / top left
1) Pull the center knob out half way (1 click)
2) Next press the bottom push button to adjust the hand.
Once all hands are reset, push the center knob back in fully...done
Mar 16, 2009 | Swatch Irony watch
Watches Logo
316 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
