Fan quit spinning first then replaced bad capacitor and bad ground wire then worked fine for one day then capacitor went bad the next day. replaced it again and it worked for another day. Now capacitors seem to be fine, fan is spinning just not getting cold air. what do you think?
SOURCE: Have a 620765 capacitor for
pls connect capacitor terminal as folow
fan = connect wire come from fan
C = common -connect 1 wire from power
- connect1 to compressor term R
-connect 1 wire go to fan
herm =connect wire go to compressor term S
SOURCE: I'm not getting any heat, found a burnt wire and
The fan relay that turns the thermostat on is probably burnt out as this probably controls the electric heat banks.
SOURCE: intertherm heatpump outside fan will
some times heat pumps have a fan cycling switch to keep the head pressure normal in cool weather or check the defrost relay for the fan when a heat pump condenser gets frosted it will stop the fan and reverse into cooling mode for a few min. to melt the ice and this function is done by a relay or a printed circuit board if it goes bad you wont have voltage to the fan
