Question about Hitachi 42HDS69 42 in. Plasma Television
Problem with 42HDS69 on screen displays not working
I have same problem with 42HDS69. Input is stuck to HDMI. No menu shows up. Remote works but only for On-OFF and volume. No onscreen display either.
Any ideas how to fix?
  • dan tetzlaff Jan 14, 2012
    Same issue here, started as an intermitent problem, now all the time.
    New Friend:
I have the same exact problem. HDMI works fine. Menu will not appear on the screen.
Posted on Mar 07, 2014
Same issue for 3 yrs now. Anyone has any suggestions
Posted on Dec 03, 2010
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
How to find source for model WS-28W63N without the remote control
Sometimes you can unplug the hdmi cable and power off the tv and unplug power to tv wait 10 sec plug tv back in and then insert hdmi cable. Some of the newer tvs will auto tune to the input if that dont work, try getting a universal remote program the remote to control tv if you can control tv volume, power , menu then you should be able to navigate to the input menu and select hdmi that way
Jan 13, 2013 | Samsung TV Remote Control
The message: input: hdmi Front keeps showing up in the upper right hand corner of the tv.
Try selecting your input one at a time. What happened is you choose the hdmi as your input but at the back of the tv you connected your input wires (to maybe hdmi2 or input 1 or input 2, etc. Good luck.
Jul 09, 2010 | Hitachi 42HDS69 42 in. Plasma Television
How do I play a PS3 on my 42HDS69 I cant get it to work, I change the input and it does nothing .
I know it seems obvious but have you gone into the PS3 video settings menu and changed output to HDMI (assuming your using an HDMI cable)
Jan 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
JVC 40 inch LCD digital inputs (1 and 2) no longer works. Standard video and component cable inputs work, but not HDMI. Please help
This TV has a sensor that deactivates the inputs when light is sensed. perform this procedure to correct it:
1. press "Sleep" button on the remote
2. while "Sleep timer 0" is showing, simultanuously press "display" and "video" button on the remote
3. you should be in the Service menu of the TV....if not you should do the steps again
4. select "self check" from the displayed options.
5. when the "self check" menu is displayed, Power off the TV.
6. unplug and replug the TV.
7. Check the digital input.
if the input never worked for you, it is possible that you have the DVD/Bluray/whatever set up incorrectly. I don't think this TV accepts 1080P resolution so make sure it is set to 1080i or lower
Jun 23, 2009 | JVC LT-40X776 40 in. LCD HDTV
Cant bring up the onscreen menu on my tv
Greetings ! Hopefully you followed the instructions on page 18 - 20 of the Yamaha manual... then set the Flat screen or monitor to one of the two inputs that you view movies or dvd's on . I would try it first without HDMI cables as even the book states some monitors do not accept or see hdmi. try it with the dvd cables.
You have to follow the book carefully as I have the same system . Its a complicated system and I was informed , "a lot of people do not know how to set the system up and end up returning a perfect system..." from the Geek squad from Best Buy. Just follow carefully the manual.
Apr 01, 2009 | Yamaha RX-V663 Receiver
42HDS69-INPUTS
couple of ideas ... on the TV look for the button named input you can change it to the one you cave connected to there .. I am looking up the remote press the TV button then the menu button to move through the on screen input control
Sep 19, 2008 | Hitachi 42HDS69 42 in. Plasma Television
LG HD Digital Video Recorder LST 5402P has stopped displaying menu onscreen
first i assume you are trying to watch the unit through AV. If this is the case, turn on unit, press "Display Format" on the front of the unit, keep press it till you have "YPBPR" displaying, press select on front panel, next press "Display Format" again till you come to 576i, press select. Now press menu and it should display. If this problem occurs with HDMI, simply change the display settings to HDMI, and 1080i. Hope it helps, Murder-face.
Jan 13, 2008 | Televison & Video
Hitachi 42HDS69 42 in. Plasma Television Logo
325 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
