Question about Kenmore 63942 Dryer
I hear the motor running, but the dryer does not spin.What should i do?
  • 672 Answers
The belt may be worn or broken or the drive pulley may have loosened. The easiest way to access these parts is to remove the case. On some models you can tip the machine back a little and look underneath to see the motor. When tipping back always disconect the power and get someone to help support while looking under the machine. Also take care not to damage the discharge ductwork.
Posted on Jun 28, 2009
  • 27 Answers
Your belt has been either stretched and no longer fits snugly around the drum enough to turn it or its snapped all together
in all honesty unless you've done it before i'd call a repairman, for two reasons its a 220 appliance and taking a newer drier apart means lots of little skrews and cut fingers
DRYER WONT SPIN
Can you hear the motor run after you attempt to start dryer? If so, check for a broken belt. If not you will need futher troubleshooting, Could be motor, timer, etc.
Mar 29, 2014 | Frigidaire Affinity ATF7000ES Front Load...
My dryer will not spin
If you can hear the motor running but the drum is not spinning then you probably have a broken belt. If the motor is not running could be anything from a bad door switch to a bad motor. Hope this helps
Aug 30, 2011 | Whirlpool Dryers
My dryer won't spin.
If you can spin the dryer tub by hand, it aint jammed, if the motor is running you may hear it. could be a snapped belt or motor carbon brushes are worn,
pete
Nov 10, 2010 | Dryers
Kenmore 86874800 electric dryer. It doesn't spin (rotate).
Can you hear the motor running? If so, you need to replace the drive belt. If you can't hear the motor running, you will need to get a schematic from the Sears/Kenmore website and check for voltage inside the cabinet. You could also buy another used dryer for $100. This route is certainly cheaper than paying for a service call and repair.
Jan 19, 2010 | Kenmore Dryers
Belt borken. Should I hear the motor spinning
Good day,
Yes the motor will run with or without the belt. The blower discharging air out of the back of will still work,
as well.
Dec 21, 2009 | Kenmore 62602 Electric Dryer
The dryer does't spin
do you hear the motor running????? Could poissibly be one of the fuses/breakers or if you hear the motor likely the belt is broke...a tricky repair....
Nov 01, 2009 | LG DLE2514 Electric Dryer
Dryer will not spin, but motor runs
if you can hear the motor spinning freely, the belt that connects the motor to the drum probably either broke or slipped off
Oct 22, 2009 | Dryers
Heats but wont spin
Can you hear the motor running when it is supposed to? If so, the belt has either broken, the belt tensioner spring has broken or come off, or the belt has come off of the motor pulley. If you hear humming, but no motor running, the motor start capacitor is likely bad and should be replaced.
Sep 30, 2009 | Kenmore 73952 Gas Dryer
Dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Sep 03, 2009 | Dryers
Won't spin anymore. Comes on, but barrell won't spin. dead motor?
Do you hear the motor running? It may just be a broken belt. If it is in fact the motor it can be replaced.
May 28, 2009 | Kenmore Dryers
Kenmore 63942 Dryer Logo
60 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
