Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Lamp replacement I need to know where the lamp is located.
  • edwar55 Nov 07, 2007
    thank you
  • 105 Answers
On the front of your tv, remove the front black cover on bottom under this you will see the lamp cover. remove this then the lamp.
Posted on Nov 07, 2007
I have saturn ion3 sedan 2005 . My stop light not working. I checked the switch and fuse. They are OK. But didn't find relay. Where I can find it? Thank you.
The 15-amp STOP fuse located in the body control module (BCM) supplies battery positive voltage to the normally open stop lamp switch. When the driver presses the brake pedal, the switch contacts close and battery positive voltage is supplied to both left and right stop lamp assemblies and the center high mounted stop lamp (CHMSL), through the BCM. The stop lamps are grounded at G401 and G403.
Do you know where the BCM is located ? If it should come down to it that the BCM needs to be replaced , It has to be programmed an the dealer is your best bet !
Replace the BCM. Refer to Control Module References for replacement, setup, and programming.
There is no relay ! !
Jul 04, 2015 | Saturn Cars & Trucks
Lamp error
How do you know its a lamp error?. if it is the scanner lamp its located under the glass. And you replace the whole module not just the lamp, or is it the fuser lamp, you just replace the whole fuser section which is the Hot part.
Jan 19, 2014 | Konica Minolta PagePro 1390MF All-In-One...
2008 Entourage right turn signal blinks 2x faster. Does this mean i need to replace fuse? Where is fuse located?
you might have a blown bulb. turn on 4 way flashers (hazard lamps), walk around vehicle and see which one is not working. Replace burned lamp.
Aug 07, 2012 | 2007 Hyundai Entourage Limited Minivan
I have an amana convection/microwave model acm1580as that needs a lamp replaces. I bought replacement lamp and after practically tearing appliance apart I located burnt out lamp. Now I don,t know how to...
Hi, since you have located the burnt lamp, all you need to do is to unscrew the burnt lamp and replace the new one by screwing it in.....
You only need to unscrew to remove the lamp and if you cannot remove by unscrewing because it is stuck in, then you need the assistance of an electrical tech to help remove with his pliers....
Mar 26, 2011 | Amana ACM1580 Convection Microwave Oven
I am trying to figure out how to replace my replacement lamp, but do not know where it is located.
Lamp Access door for Sony KF50WE610 is below the screen on the front of the TV. This page shows location of Lamp access door and DIY bulb change instructions for most SONY LCD TVs:
DIY Bulb Installation Guide
XL-2000 XL-2100 XL-2200
XL-2400 XL-2500 XL-5000
XL-5100 XL-5200 XL-5300
This page shows Lamps and bulbs for all Sony LCD Projection TVs
Sony Lamp Gallery
Look at Optical Engine Faults before buying a lamp or bulb. Replacement bulb will not repair these problems.
Feb 05, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Lamp Light flashes, possible replacement of lamp needed?
there should be an acess panel on the back and just replace it they cant be checked if the lamp light comes on is gone
May 07, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
HAve a 42 Sony Wega rear projection TV. Need to replace Bulb but dont know were bulb is. Do I need to take off back panel?
the lamp is located in front below the screen. there is a plastic panel to remove(full width of t.v.) the lamp is in the center held by allen head screws(replacement lamp will supply an allen wrench) be carefull not to get fingerprints or dirt on front of lamp(premature lamp failure will happen) hope this helps.
Jan 16, 2010 | Sony Televison & Video
Ware is the bulb located in the 50inch magnavox
  • hello here is what you need to know .on the location of your lamp & the right way to replace it. first thing is to, Turn off and unplug the unit before you replace the lamp.
  • Take care that no screws or other metal objects fall into the display interior. Such items could cause fire or electrical shock.
  • Do not remove the lamp except to replace it. Careless handling can cause injury or fire.
  • Do not replace the lamp immediately after the display is turned off. The high temperature of the lamp could cause serious burns. Allow the lamp to cool down at least two hours after turning off the display. display. 051021165929_314.gifthank you for useing fixya.com .
Jul 24, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Need to know how and where to change the lamp?
the lamp is behind the speaker cover, behind a little door in the front of the set. it is off to the left. you will need a philips head screw driver and a flat blade screw driver. don't force the new lamp in or you will push the connector behind it out
May 18, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
