Question about Hitachi 42PD6600 42 in. HD-Ready Plasma Television
Hitachi 42pd5200 TV switches between on and off when turned on.
    President:
  • 1,077 Answers
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
  • chatterjeeba Apr 06, 2011
    advice is OK.But where to buy circuit diagram?
    chattergee.baribdra@gmail.com
I have hitachi 42pd5200. No sound I recently moved house & speakers were thrown out by mistake. What speakers do I need to buy that will work please
The output from the TV should be 6 Ohm, 12 Watt. You can use any speakers with same or higher rating e.g. 8 Ohm, 15 Watt. Don't use speakers with a lower rating e.g. 4 Ohm as this will put too high a load on the speaker driver circuit.
Apr 06, 2016 | Hitachi Televison & Video
Thin vertical line on plasma, 4 inches from left hand side
According to what i could find, there is no way to actually SOLVE the problem, this is what i did find; The plasma display panel is lighting the phosphors by the discharge of internal radiation. Depending on the screen contents, in rare cases this may cause vertical stripes to appear because of failure to light. Please note that this is not a malfunction.
Aug 10, 2007 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
Hitachi UltraVision Tv Keeps turning off. The lamp LED blinks. Both light engine and lamp are new.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
google.com/+GopakumarGopalan
Nov 13, 2013 | Hitachi 50V720 Television
When i switc on my hitachi 42pd5200 tv the standby light turns green but the tv does not start up, any ideas of how to resolve the problem?
if the LED turns green and remains green that means the TV is likely starting up just fine.
if you can shut it off (i.e. turn it back red) and then back green, i.e. if you get it to respond to your command that means the TV is actually operational.
What is NOT operational is part of it , that is not central to the main board's functionality, e.g. the circuits that have to do with the display itself.
In your hitachi that is most commonly the buffer boards and the Y-Sustain board, which sometimes fails and sometimes does not when the buffers fail.
Sep 25, 2012 | Hitachi Televison & Video
When TV is turned on we get no picture or Audio Hitachi 46ux25k
STK ICs need to be replaced STK392-110s use 150s Mats Has them 1-800-628-1118
May 08, 2010 | Hitachi 46UX24B/25K 46" Rear Projection...
Hitachi 42pd5200 tv is there an inturnal fuse or reset
yes there are several fuses inside but if one of them is not ok don not replace after measering!
Aug 03, 2009 | Televison & Video
No power to my Hitachi 42Pd6600 plasma tv
the master switch at the bottome of the TV per Brianbuy solved my problem...Thank you!
Jan 20, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
TH ETV TURN OFF ITSELF
the cooling fan could be going out
Dec 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Thin red line on Hitachi plasma
If it goes all the way from top to bottom, you have a bad panel. much to expensive to repair
Hitachi 42PD6600 42 in. HD-Ready Plasma Television Logo
641 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
