Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Screen on 42 inch green after patch to resolve other problem
I have a sony grand wega, I had a sony tech come and install the patch, (the tv was going on and off), he installed the patch, when the tv came back on it looked yellowish/greenish, so I ordered the new bulb, that fixed the on off problem but it is now greenish, could that be from the software install and what are my options for fixing this? How much is an optical thing and it sounds expensive
    Brigadier General:
  • 8,619 Answers
Hi
The problem is that your Convergence chips(IC's) (amplifier chips that send a signal to the projectors) are shot. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 28, 2009
Hj Sony Grand WEGA KF-42SX300 42" LCD TV
Check the options of contrast or tint, if your adjust them to your preferences then maybe it will work, or maybe it is just old. Glad if I helped.
Feb 05, 2014 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sony 72 inch 1080 HD TV - yellowing in the center of the screen. Recently replaced the lamp and adjusted the picture settings but the yellow patch remains. Please advise what is the best thing to do to...
I hate to say it, but your Optical Block aka Light Engine is going out on you. Sony has been extending Warranty on these since they have been so problematic, but this has been on a case by case basis. Your best bet is to call Sony and keep at them. If this gets you nowhere, it will not be cost effective to fix.
Apr 19, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a slight yellowing in the center of my screen. We recently replaced the map, and have tried adjusting all picture settings but the yellow patch remains. It's a Sony Grand Wega, by the way.
Don't know if the DLP tvs have a Deguassing coil,inside it bazel frame.Take ur tv aparts check,see if u have big coil rapping with ectrical tapes fit inside ur bazel frame of ur tv.If yes,the componnents parts that make the coil work it dead.This coil demagnictize for the tv tube first turn.All regular small CRT tube tvs '30 inches and down have this dequassing coil inside it bazel frame.
Apr 11, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
There is a green patch in the bottom right corner of the screen.
Magnetic field prob.move the tv all around to get better or help less green color patch.Like move north south,southeast,southwest get less magnetic field interferences.
Oct 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KF42WE610 42" turns on and off
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Please make sure that the videos sources are connected properly to the TV.
Try Power Resetting the TV.
Please disconnect the power cord from the wall outlet (for approximately 1 minute), then reconnect the power cord and check whether the issue is resolved.
Also try connecting the TV to a different wall outlet and check if that helps.
Jun 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
42 inch sony grand wega
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jan 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
