Cab Faby Not Freezing
could be any number of things: mixture being too rich (add more water), timer is off (reset defrost timer on side), 4-minute timer is not turning on compressor (inside right front panel. unplug thin blue wire harness, turn middle screw until compressor turns on), the refrigeration solenoids (is there a click from the back when you turn the switches on), does the compressor turn on, does the fan turn on (if there is no air flow, the overpressure sensor will turn the compressor off), or maybe there is a leak. if it is the last case, you will need a professional to take a look at it.
