Seems to be just the digital channels that get dropped, i.e. channel 5 is analog and channel 5-1 is digital NBC! Will be watching the digital channel when all of a sudden it will no longer be there but the analog channel will be!
SOURCE: No analog channels or audio.
Hi Janet, Could you provide the number of your repair service. I have the same exact issue and I am unable to find a service repair technician who knows how to do this!
SOURCE: How do I set my PT-44LCX65 up to receive broadcast HDTV signals.
You should use the auto-program function in the customer menu. It will prompt you to select which antenna input you wish to program and then ask if you are on cable or receiving signals via "air" or "broadcast" mode. Allow the TV to load all the channels. You may notice that the auto program mode may move along quickly during the addition of analog channels and that during the scanning of the digital channels that it may look like nothing is happening. Patience is a virtue here. Wait until it has completely scanned both analog and digital bands and you will recieve both versions of the station's signal. If, for example, you have a local channel 5, the digital version will be 5-1, and so on.
michtech
SOURCE: Have no volume on only one channel on Panasonic TH-42PX60U
Try the SAP - same thing happened to me and had to cycle through the audio tracks to get audio back on for that one channel. Good Luck!!!
SOURCE: how do you delete unwanted digital channels we
Go to Setup, Tuning Menu, Analog Program Edit, Select the Channel to Edit and set it to skip the channels you don't want to see anymore.
SOURCE: Panasonic TH-L32S1OZ digital TV set. Message on
Make sure the cable is hooked up then press ok on your remote (or enter). If you have your tv hooked up a different way (like hdmi) just change the tv source to the correct one.
