Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Sony projection tv no power
Hi i have 50" sony rear projection tv problem is it doe'nt turn on when i switch the power button all i get is blinking red light pls help!
  • Bobby Guel Jan 01, 2008
    I have the same problem with my 55" sony wega model KDF-55WF655. I turn the power on and no green light at the bottom, I took off rear lower panel looking for blown fuse, but could not locate any fuses. Is there a reset button inside or out? Could it be the power supply, if so How and where can I take Voltage checks?
    Bobby G
I was very happy to see poolmvp1's solution . We already bought the manual and ordered the part.I just want to make a correction on the manual website .It's servicemanuals.com ,not servicemanual.com...It took me a while to figure it out. I just hope it will work for our TV, I don't like someone to repair my TV, who knows what they are going to break while trying to fix it ,so i think it's a great idea to do it yourself!
Posted on Mar 01, 2008
  • mehtap Mar 01, 2008
    Sorry I made a mistake when i was trying to make a correction...It will be servicemanuals.net not servicemanuals.com
    Problem Solver:
  • 5 Answers
I purchased a service manual for $16.99 from ServiceManual.net. I downloaded the manual. Read it and you have to make note of how many times the power LED blinks red. My 55" Wega was blinking 6 times then pause then repeat.
The manual indicated it was a "Low B error, No "DD 6V" output ( G1 Board) No picture/No Sound.
The manual gave me instuctions on how to remove the G1 Board. I took it out and clean off the dust reseated the G1 Board, still the same problem. I order an new G1 Board, part# A-1060-177-A from the "Partstore.com" for $186.25
Problem is fixed and I save $350 on service call.
Bobby G aka poolmvp1
Posted on Jan 02, 2008
  • 36 Answers
What model is it? This could be a number of things, depending on the model of the tv
Posted on Dec 30, 2007
3 Suggested Answers
electronick
  • 505 Answers
SOURCE: 6 red blinks wont turn on sony rear lcd projection
thermal fuse. it sits below the lamp and has popped. replace with new fuse or just short (eliminating fire protection) let me know if you need instructions.
Posted on Dec 09, 2008
  • 1606 Answers
SOURCE: replaced bulb on 50 inch
Did you clean out the lamp ventilation duct in the back of the set? If it's clogged with dust you could have an overheating problem (this also kills lamps). You may need to unplug the set and remove the back cover to make sure you can evict all of the dust bunnies in the duct. Also, vacuum out all of the vent slots in the back cover. Try not to get any dust into the bulb or optics.
Safety notes: the set should have been off for at least 30 minutes before doing anything to avoid getting burned on the lamp. Do not touch the electronic circuit board, even if it is dusty (just use your breath to blow the worst of the dust off the circuitry). Touching the circuit board or using a vacuum cleaner on it can cause damage by static electricity charging. There is also a possibility of getting an electric shock from capacitors still holding a charge. Normally, this stuff is nowhere near the lamp ventilation hardware, so it should not be a problem avoiding it. But definitely make sure you unplug the set before doing any of this.
If this doesn't fix it, repost and we'll look for the more arcane answers.
Posted on Oct 06, 2010
Why does the power button blink on and off and the TV doesn't turn on?
There may be an open internal fuse or the power supply may have failed.
May 25, 2015 | Philips Televison & Video
I have a sony 50". in the power button, a red
i have a sony 57". in the power button, a red blinking light blinks 11 times.
KDP57W5655
Nov 28, 2010 | Sony KP-51WS500 51" Rear Projection...
When I try turning on the TV the power/standby light flashes green until I turn the TV off, no picture appears.
If Sony KF-60WE610 does not show any Red blinking light then it is Lamp that need to be replaced because existing lamp has reached to end of its life but still not dead nor broken and causing problem.
If lamp got dead or broken, tv will show you Lamp light blinking.
Replace lamp in tv to solve its problem.
Hope these info will help you.
Please buy Sony original lamp for good picture in tv.
Let me know if you have any question.
Thanks.
Nov 04, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
My sony 50" wega just quit. No picture , no sound , no nothing ?
If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code.
And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it.
Still problem? let me know with exact model number of your Sony TV.
Thanks.
Jan 02, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony HD-TV KDF-50E2000 blinks 15 times pwr button then turns on. After about 2 hrs turns itself off and blinks 40 times then turns itself back on. shorter and shorter on time thoughout the day. No led...
Symptom shows Lamp is getting weak and its time for new Lamp in TV.
Lamp replacement procedure is written in user manual.
Please buy Sony original lamp for TV safety.
Thanks.
Jul 03, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
When switching the tv on onlypower/standby red light comes on not
How many blinks when its red ?
The blinking is a code from the microprocessor telling why it's not turning on.
Apr 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
I have a sony grand wega model kf-42we610 I will be watching tv and it will turn off on it's own and then come back on 30-60 seconds later. If I turn it off the light under the power button will blink 5...
Check your lamp cover on the rear it may be loose which will cause the tv to turn off. Also the light under the power light is the lamp indicator. If it is blinking it may be getting ready to fail.
Jan 29, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
461 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
