Question about LG VENUS Cellular Phone
Phone powers off on own after not being used a while
    Problem Solver:
  • 6 Answers
THERE IS A SMALL LOSING IN UR PHONES BATTERY.
Posted on Jun 28, 2009
Nid answer on how to restore my it2090
1. Turn off the phone 2. Press and hold the power button and at the same time the down volume button 3. When the itel logo appears, press and hold the home button. 4. Release all buttons once you see the yellow warning sign and the picture of a phone. 5.Press the up volume button once, then use the volume down button to navigate to select wipe data /factory reset then use the power button to confirm your choice accordingly. 6. Use the down volume button to select yes -- delete all user data, then use the power button to confirm. 7.Use the power button and select reboot system now, You are done Wait for your phone to restart. 8. Add me on FB to say thank you [FB ID: maitre plat] Your phone will be faster than ever now. Set up your phone now and enjoy lol.
Jun 15, 2017 | Cell Phones
Line in use
Hi this problem is more common than you think its caused by the power surge you get when the electric is turned back on you also get this problem due to lightning strike their is absolutely nothing you can do to repair the phone as their are no servicable parts and the chances of getting a new board for the base is going to be nigh on impossible
Feb 12, 2008 | Panasonic KX-TG6073S Trio Cordless Phone
M950 turns on but wont go to home screen
You will need to factory data reset your phone if you are "hanging on startup" (stuck at logo) here is how:
WITH THE PHONE POWERED OFF --
Press and hold the volume up key.
Then press and hold the power key.
When the Samsung system starts release power key
When the Android system recovery appears, release the volume key.
Scroll to:
Wipe data factory reset using the volume down key.
Use the power key to select Wipe data factory reset.
When the options present scroll to "Yes."
Use the power key to select "Yes."
Use the volume down key to scroll to Reboot system now.
Use the power key to select Reboot system now.
Phone should now restart.
Nov 28, 2013 | Cell Phones
My phone only works when it is plugged in with a battery, but it is fully charged. If i take the battery out and use solely the power cord, it does not work.
I do not know anything about the LG LX370 phone but I have NEVER seen a cell phone that works with no battery.
A phone is a transmitter and requires a lot of power when it is in a call. This power cannot be transmitted down the thin cable and connector that you use to charge the phone so it uses the power from the battery.
You need the battery in for the phone to work, the power cord input should only provide a current limited charge for charging the battery.
Most chargers are rated at about 5V and a maximum of 500mA, a phone can require well in excess of 1Amp when in a call.
Feb 06, 2011 | Sprint LG LX370 Standard Battery LiION...
How to power nokia 5610 xpressmusic without using the power button?
My dear friend, sorry, there is no other way to power on your nokia 5160 xpress music phone. The only other way you can power it on is to get the phone opened and use an object to touch the power button manually.
If your phone does not power on by the power button, first ensure that your battery is fully charged. Then you check if your phone is working properly. Test your battery by inserting it in another phone and try to charge it for about 2 hours, then you power on the phone to see if the battery will turn it on. Then you insert a well charged battery into your phone, then you power it on, if it turns on, then it means it is the battery you are to replace, but if it does not, then it means there is an internal problem with the phone.
Hope this helped you.
Jan 09, 2011 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
How power need Cisco 7941G-GE IP Phone
These phones can take their power from a Power over Ethernet switch, where all you need to do is plug the phone in to the switch and it gets its power from there.
You can also get power cubes for these phones, but they do not come with the phone as standard, as most people like the convenience of having the power coming from the switch, and not needing to use up a further power socket in the floor/wall.
Hope that this helps!
Nov 06, 2010 | Cisco 7941G-GE IP Phone
Battery power is very weak
    1. Try this first  power off your cell phone and charge it for 6 hours
    2. remove the charger and power on your cell phone start using it
    3. please note that don't use your phone while charging unplug it if you need to use
    4. only recharge it when it shows battery is low
    5.  please buy and use original battery and  charge
    6. I am sure that you can see the difference
    Jun 20, 2010 | Nokia 6500 Slide Cellular Phone
    Camara module not ready
    Sir,
    If you have original charger:
    1. Power-Off phone
    2. Connect charger to phone
    3. Connect charger to 220/110V
    4. Charge phone during 30-40 minutes
    5. Power-On phone and use it
    If you don't have original charger:
    1. Remove batetry from phone
    2. Use external power supply and charge battery
    3. Power-On phone and use it
    Thanks
    Good Luck
    Aug 17, 2009 | Handmark Software MobileLists (950142) for...
    I use the phone only very occasionally. Hence very often, I let the battery die, and re-charge it when I need to use the phone. The problem is that every time after recharging it, all I can see is the...
    Ok, this one is kind of odd, but through experience I know it's right. When you plug in the charger to most phones, the phone will use that power to run the phone as well as charge the battery. However, in this case, the phone does not use the power supplied by the charger except to charge the battery. So, until the battery has enough power, you cannot use it. Even though the phone is plugged into the charger, the battery is what is being used, not the power coming from the wall. I hope that was clear enough, I know it's an odd situation.
    Mar 28, 2009 | Nokia 2610 Cellular Phone
    Katana 6600 Keypad Inop
    PULL BATTERY SET OVER HEAT VENT FOR A COUPLE DAYS OR USE A BLOW DRYER.NEVER USE ALCOHOL,IT WILL DAMAGE DIFFERENT TYPES OF COATINGS.FIND A SAFE SOLVENT.I USE MISTY ELECTRONICS CLEANER.DO NOT KEEP POWER CYCLING PHONE UNTIL YOU HAVE FINISHED.BE VERY CAREFUL TAKING APART.
    GOOD DAY
    KZ
    Jan 16, 2008 | Sanyo Katana SCP-6600 Cellular Phone
    LG VENUS Cellular Phone Logo
    Top LG Cell Phones Experts
    skiffy99
    skiffy99
    Level 1 Expert
    Raphael Josiah
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
