Question about Yamaha Full-Size Keyboard
Some of the keys on my yamaha psr 260 not working.
Some of the keys on my keyboard not working. how can i get them repaired. can i do it or do i need a piano repair man
robocop
  • 90 Answers
SOURCE: Instruction manual for a Yamaha PSR 195 keyboard.
Try going to http://www.yamaha.co.jp/manual/english/index.php. There, you can try to find your owners manual for free.
Posted on Jan 22, 2009
SOURCE: How do I take apart Yamaha PSR-280 keyboard to clean keys.
There are 17 screws on the underside of the keyboard that need to be removed. The base cover can then be removed. This gives access to the keyframe assembly which can be removed.
Posted on Feb 08, 2009
SOURCE: Yamaha PSR-510 Keyboard
There is no need for a manual. It is so easy to operate because it is designed for easy opeating. If you need a manual to operate the PSR-510 then you really won't be able to operate it even after studying the manual. But here it is just in case you can by some miracle!
http://www2.yamaha.co.jp/manual/pdf/emi/english/port/PSR510E.pdf
Posted on Feb 10, 2009
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Posted on Feb 14, 2010
SOURCE: yamaha psr s900 screen/display gone bad
MR SATISH IF YOU WANT TO SOLVE THIS PROBLEM CONTACT:9887070565,94136768(ANAND NARWAL)FROM RAJPUTANA ENTERPRISES
Posted on Aug 07, 2010
I have a Technics PR-305 Digital Piano. I had a couple of guys come out to see if they could fix it. Only the LCD display and the front light worked. It must be the power supply.
Technics, digital piano, keyboard repairs, repair, service ...
www.mikebarden.com/technics-electronic-digital-kn-pr-px-piano-keybo...
technics, technic, tecnic, digital piano repair, service, servicing, digital, electronic, ... pr200, pr250, pr270, pr3, pr300, pr303, pr305, pr307, pr350, pr370, pr40, pr5, pr50, ... It needs extremely specialised repair work which must only be carried out by .... nodisplay, LEDS don't light up (except for the one on the front of the piano ...
Dec 18, 2015 | Music
How do I fix a stuck piano key on a upright home piano
You'll likely need to try removing the keys, so you can see if something is stuck underneath it. That would be my first move.
In order to do this, follow these steps:
The front panel and the keyboard fall are designed to be easily removed for tuning purposes anyway.
To check it out....The front panel likely has a little clip either side near the top on the inside. Just undo these clips and lift the panel out. The keyboard fall should then be easy to lift out too.
There may be a long wooden rail which you need to take out also. Once inside, the keys themselves can be carefully lifted off the central spikes on which they sit.
Remember how you did this so you can get them back in again.
Since your piano is so old and worn, Often times, the wooden rail in front of the keys (just above your knees when you are playing) bows inwards a little due to age and temperature/humidity fluctuations. This then causes the little white front bit of the keys to jam against the wood and you have to physically lift the keys back up to return them.
If this is the problem you will need to take out the keys and shave some wood off the inside of this rail to allow the keys to move up and down freely again.
Or sometimes you may find you have a small object caught under a key or two. Much simpler to remove and free up your keys, if this is your problem..
Hopefully, this is all you will find wrong with your piano.
If all else fails...
I wouldn't attempt to tune your piano by yourself. I would seek out an experienced piano tuner for that.
But it is worth attempting to repair it first before you go that far.
Good luck !!
Feb 26, 2015 | Music
I CANT PLAY
Hi I have a Technics PR-305 Digital Piano, The LCD Screen in the center of the Piano, only lights up in the Center of the LCD Screen. I only see the center part of it, Can that be fixed, or not repairable? Also have a distortion sound in the Speakers Can that be Repaired, or would I need new speakers?
Jan 14, 2014 | Yamaha PSRE413 Keyboard
Yamaha P-70 digital piano. A few keys are making a loud knocking noise. The note still sounds, but the knocking noise on the few keys can be heard at the other end of the house
There's an extremely comprehensive pair of videos about repairing this problem on YouTube thanks to David Allyn. I have embedded them below, or you can search "P70 Noisy Keyboard Repair".
Jan 03, 2014 | Yamaha NP 30 76 Key Lightweight Digital...
Is there a Yamaha school of instrument repair? Pianos, Keyboards and Organs
Yamaha prefers to MAKE the instruments rather than conducting repair schools... they may have some very specialized schools for individual types when first introduced. With the situation in Japan right now such classes would be cancelled I am sure. Instrument repair is so specialized other than basic piano repair/tuning that you will find few if any courses. For piano repair you might want to search YouTube for videos. For organs and keyboards, detailed electronic knowledge and the service manuals are what we have to work with. You need both experience in digital and analog plus test equipment including oscilloscopes and signal generators as a start.
Apr 13, 2011 | Yamaha Music
After transport the keyboard,half of the keyboard below c4 not work.
Probably a cable has come loose inside the unit. The keys are scanned by the internal processor as a matrix of two contacts per key. Often the keyboard is divided into two sections.
You will need to have it repaired or if you are electronically adept, open the case and look for obvious problem.
Mar 17, 2011 | Kurzweil SP3X 88-Key Stage Piano
I need to repair a sticky key on a P120. Is there a repair manual?
Call around to local music stores and ask about the closest authorized Yamaha repair center. If it is still under warranty, they should replace the keybed free of charge.
Here is a great website with the do's and don'ts about self keyboard repair. http://www.mikebarden.com/view.php/area/1/digital-piano-repairs-keyboard-repairs
Sep 17, 2009 | Yamaha Full-Size Keyboard
Kurzweil piano keys are clicking seems to be worn out.
I don't see you doing any damage by having a look but I would get a piano tuner or repairer in to investigate the problem expertly - no slight on you. But if your Church congregation depend on it it's well worth the money.
Good Luck
Sep 02, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
I have a Technics digital piano with 1 dead key. The piano is about 10 years old and in great shape. The key stopped working after my toddler started banging on the keyboard. Is this fixable?
If your piano is the same as mine, there is a rubber membrane with contacts imbedded in it that sits on top of a circuit board. The key pushes the contact in the membrane onto the contact causing a note on. What happens is the cylindrical part of the membrane that holds the contact can get torn and the contact will no longer travel in a straight line to trigger the note. The entire membrane strip has to be replaced. The strip on my piano was discontinued and I had to manufacture one from an extra Roland membrane that had some bad contacts in it. You will have to contact Technicsat www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd for support. If you don't feel comfortable tackling the repair yourself consult a good piano tuner/repair place in your area for advice.
Jun 22, 2009 | Music
Yamaha Full-Size Keyboard Logo
533 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
