2003 Ford Focus Logo
A
Anonymous Posted on Jul 03, 2014
What will cause my radio,clock and power outlet not to work?
Recently my car wouldn't start. Replaced battery. Have noticed since my radio,clock and power outlet will not work.
David Burbee
Level 3:
  • Ford Master 1,871 Answers
  • Posted on Jul 03, 2014
David Burbee
Ford Master
Level 3:
Answers
1871
Questions
Helped
1056845
Points
1009
Let me ask a few questions: The items mentioned, radio, clock and power outlet...are these the only items not working? does the instrument panel light? Also , does the cigar lighter work? Lastly check fuse # 7(40A) in the battery junction box
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
4 Related Answers
Anonymous
  • 783 Answers
  • Posted on Mar 12, 2009
SOURCE: Radio Not Working
There are 3 fuses in the interior fuse panel that feeds radio.
no. 11(10amp) is ignition switch power to the radio it comes into radio on the TN/LB wire.
no. 27 (10amp) is hot at all times and comes in on OG/LG wire.
no. 12 (5amp) is hot in run or accessory and comes in on YE/BK wire.
Check these with 12V test light at fuse and at radio connector.
Anonymous
  • 776 Answers
  • Posted on May 26, 2009
SOURCE: replaced battery - need to reset clock / radio won't play
Yes.. your problem is a micomp (micro computer) issue. There is a communication problem between the micomp and the touchscreen. Replace the micomp.
Anonymous
  • Posted on Oct 19, 2009
SOURCE: car starts sometimes & sometimes it don't.
check fuel pump presure
Anonymous
  • 1340 Answers
  • Posted on Aug 19, 2010
SOURCE: Our vehicles battery went dead
If the stereo is a factory stereo,you need to call Ford dealer to get the unlock code,this is common with many different makes.As far as the rest,when a battery is replaced,different makes have certain methods required to "reset" the systems.I do not know why they do it.Is it really going to deter theft,you know what I mean?Anyhow,ask the dealer if that applies to your vehicle too,a reset.Tell them you replaced the battery and all the rest what you told me.
Good luck! Greg
2010 Impala: radio wont power on, no accessory outlet power
you need to input the code anytime the battery has been disconnected, call a dealer, its not free
The auto. door locks, radio, and dome lights not working
You have burned out the vehicle's controls modules, call your insurance company, they should cover this type of unfortunate mistake.
Every time i start the car it resets the clock
The clock and radio memory use a different power source than the radio - - that source is not controlled by the key switch. I would check the fuses first to see if you blew one that is hot all the time.
My 2000 Toyota LE wouldn't start one day, so I got it jumped and took it for a drive to charge the battery. While at a red light, my car stalled out and died in the middle of the road. I got it to a...
probably a fuse, unless its an aftermarket radio that lost complete memory mode, and need to be re coded to work. the easiest way to check this is to look for the power wire, on your car its a blue wire with a yellow stripe for the battery one, and a gray wire for the ignition one that supply the radio with 12 volts, see if they have power,
Truck would not start and I began the process to jump the truck. I put cables on truck battery and then noticed truck had power and started the engine before I hooked it up to another vehicle. I then...
A loose cable end can cause all those things to happen. You should clean the cable ends and the battery post and tighten them up and see if that works for you a loose battery connection can cause a lot of problems.
1helpful
I have a 2006 Pontiac GT G6 Coup. When we first bought it back in Nov. 2010, it was fine. After a month or two, the clock would reset almost everytime the car was started, radio stations would NOT get...
sounds like a problem with the ignition barrel.the wiring is loose or the connectors are loose or the barrel is faulty,unless thse are all run from the onboard computer.
Instrumental panel, i believe this is the problem why my air bag light stays on, power windows, locks, seat belts does not work. the clock or radio does not as well. Also my alarm is not working. I...
Here is a link to a factory repair manual for model year 94, it is the same car as fact as mechanical go and electrical systems, look up the wiring and find the common power source for the things that don't work.. You will need a RAR file extractor tool, you can download one free on the internet. http://diyservicemanuals.com/nissan-maxima-service-repair-manuals
1helpful
Reset radio but can't reset clock
just press the clock button for a few seconds then press it again for few seconds and it should stop blinking once it stops blinking press the clock button down again and hold then once it starts blinking release the clock button and adjust the hours and minutes
Radio not working
Radio will light up the clock works
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
