Question about Black & Decker Lawn Hog 18-Inch 12 Amp Electric Mulching Mower
Lawn hog 18" electric. Hit a rock, kept running, vibrated, stopped, now when I try to start it it short circuits the house electric as soon as I pull the on lever??? Looked at wiring at engine and control lever. Nothing burned or disconnected. Could the ground be the coulprit?
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello sir, talked to black & decker thay said thay would be glad to supply you with a manuel and how to,just call them at ,1-800-544-6986, i found them very helpfull, hope this helps,MrFixIt, oh could you please rate this solution, thank you...the manual is useally free...
5 Suggested Answers
  • 22 Answers
SOURCE: I have Black and decker electric lawn mower does not start
one of the problems i found with electric detectors was that they do not tell you if there is a break in the neutral cable so you could have a break there,another problem is that the levers can break inside the cover giving the impression that it should work but is not making contact with the switch ,hope this helps
Posted on Mar 30, 2009
  • 52 Answers
SOURCE: Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Posted on Apr 15, 2010
  • 19 Answers
SOURCE: My electric mower (B&D Lawn
probably a loose or out of balance blade
Posted on Jul 05, 2011
  • 6468 Answers
SOURCE: black and decker lawn hog 18 was working fine last time used but will not start now what,s the problem
while unplugged rotate the blade a few spins to move the brushes if there stuck make sure the outlet is good and try another power cord
Posted on Aug 14, 2012
Electric lawn mower stopped working
Take off the black plastic hood (4 screws), clean debris and check connections to, and condition of, shunted brushes. They're available from B&D parts for a few bucks.
Jun 20, 2014 | Black & Decker Black and Decker Mm575 18"...
Black and decker lawn hog 18 was working fine last time used but will not start now what,s the problem
Aug 13, 2012 | Black & Decker Black and Decker Mm575 18"...
My 18" 12 amp B&D mower has become loud and vibrates so much that the wheel height adjustment pops out. Any suggestions?
Most likely bent shaft or blade. Worst case motor is on the way out maybe bad bearing or something along those lines.
Sep 18, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
My black and decker lawn hog is vibrating like crazy and then when i push it through the lawn it wants to die out
The symptoms are typical of an unbalanced blade. There is either very uneven wear or you hit a rock or something stationary and it bent your blade. It could be build-up on the blade but it would have to be huge to throw everything off balance.
Jun 21, 2010 | Black & Decker 19" Electric Lawnhog...
The mower vibrates hard I replaced the fan and
you could have a bend blade or bent armeture shaft if you hit something that hard
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
I HIT A ROCK WITH MY MM575 AND THE MOTOR STOPPED. IT WILL NOT START
Sounds as though you either broke or badly damaged the flywheel key. It is located on the shaft that comes up through the flywheel. If you have ever taken the cowling off, you know how. Just make sure to use the proper size and shape flywheel key. This key is designed to break in order to save the more valuable parts of the machine. Good luck...Lee
Sep 16, 2009 | Black & Decker Black and Decker Mm575 18"...
Black & Decker Lawn Hog 18-Inch 12 Amp Electric Mulching Mower Logo
101 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
