Error code
Err 08
The start/pause light, program ready light and program end light blink.
The motor has failed.
Shut down your machine and unplug. Turn off the tap and contact the nearest authorized service agent immediately.
What sort of machine is it? Refrigerated, Ducted, Gas? To do a full reset correctly, you must switch off at the main isolator next to the unit or at the meter box and leave it off for at least 15 minutes. A quick on / off does not reset it properly. If the unit is a refrigerated split system , and the outdoor is running but the machine is not blowing cold outside and hot inside (On heating mode) It could be due to a gas leak / shortage.
I understand that you are receiving a 08 error code on your Electrolux dryer, model# T4530. I have researched your appliance and noticed that it was manufactured in the UK. What is suggested for the North American appliances is to reset them, by either unplugging them or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this. If this does not work, I suggest contacting the manufacturer for further assistance. Hope this is helpful.
Power down the panel, remove the battery. Hold down the * and # while re-powering the panel. It will jump right into programming. Release the *and # button and proceed with programming.
U have to download resetter file http://imadeitthisway.blogspot.com/2010/09/canon-ip-2770-reseter.html http://m4sjoysaja.blogspot.com/2010/08/how-to-reset-clear-counter-canon-ip.html
looks like its making the image fine try to use a different program like imgburn to make and image of what yoiu wanna burn then use that image to write to a new disc
Dryer had been overheated (clogged or damaged air filter). Reset 3 thermo-fuses (small red buttons): 2 under top cover and 1 under back side round cover
simply reset your phone or have it flashed. Also make sure your phone is free from virus( that happens mostly if you do connect to PC or you frequently receive files over bluetooth) let me know what happens next
