Question about RIM BlackBerry Curve 8310 Smartphone
My blackberry will not take a charge - RIM BlackBerry Curve 8310 Smartphone
Have a look at the pins on the mini-USB port on the side of the phone. The ends of the small wires should all be in a row resting on the bottom (towards the back side of the phone) of the tiny slots they are in. 2 of mine were not, and it would not charge because of this. I fixed mine with the following procedure (warning! semi-delicate surgery, but easy if you're near-sighted. Will void warranty, I'm sure, so just have it replaced if you're still covered by one):
Insert a small amount of the wire from a twist-tie into the slot, pushing the end of the offending USB wire down even with the others (if it doesn't fit snug, find bigger wire).
Snip off the twist-tie as close as you can with a small pair of nail clippers, then push the remaining wire in flush with a knife point.
Apply a *small* amount of super glue to the end of the wire you just pushed in flush to keep it in place.
Worked for me, your milage may vary depending on how good you are with maniplulating teeny things.
Posted on Oct 09, 2009
    Problem Solver:
  • 14 Answers
Hi have you tried a different charger? and a different battery ?
in case you are still having problems please check www.e-repairs.co.uk for a repair price for your blackberry not charging ;)
Posted on Aug 27, 2009
  • 407 Answers
Firstly we need to narrow down the problem - Is it the charger, battery or handset?
If you can try with a different charger so if you are trying with AC charger, try with a USB charger.
If you can swap batteries, to test if another battery in your device will take a charge.
Lastly, try your battery in another device if you can to see if that device will take charge with your battery.
If you can't test on another device, I would try another battery - its probably the cheapest option. A quick glimpse at the battery in your device may give you an indication - does it look warped?
Posted on Aug 31, 2009
Bb bold wont charge
Welcome to the BlackBerry Support Community Forums.
Have you tried plugging the BlackBerry is different outlets or tried a different USB cord?
Does the BlackBerry show a charging symbol or is the LED flashing red or green?
I look forward to your reply.
Feb 24, 2012 | RIM BlackBerry Bold 9000 Smartphone
I hv a blackberry 9000 phone and the red light blinks but I cant switch on the phone even thouh its connected to a power adapter for charging
Take the phone off charge and take off the battery on the phone, you can now put the battery back into the phone. Press and hold the red power button on your phone. If the problem persist then go ahead and download the blackberry desktop manager unto your computer. Connect your blackberry to the computer and initiate the blackberry desktop manager. Once it shows connected as status between the phone and your BDM (blackberry Desktop Manager). Reinstall the software on your blackberry. Make sure the computer is connected to the internet.
Regards
Jan 24, 2010 | RIM BlackBerry Bold 9000 Smartphone
I cant get my blackberry pearl to charge!
Yes I would take it back to your purchase place for repair or replacement. Only other way to charge is by using an external battery charger: http://www.amazon.com/External-Battery-Charger-Original-Blackberry/dp/B001MEV8LI/ref=sr_1_7?ie=UTF8&s=wireless&qid=1263336321&sr=8-7
Jan 11, 2010 | RIM BlackBerry Pearl 8100
Will not charge
Are you using the AC Adapter, or USB sync cable to computer to charge? If using your computer to charge, you will need to have USB Driver for your BlackBerry Model installed. Download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5It
Could also be that your USB Port on your BB is damaged. You can use an external Battery Charger to charge your Battery http://www.amazon.com/Blackberry-External-Battery-Charger-8300/dp/B002YGYLA8/ref=sr_1_2?ie=UTF8&s=wireless&qid=1263514496&sr=8-2
Dec 23, 2009 | AT&T Blackberry Curve 8300 Smartphone
My blackberry is not switching on
Open the back cover and clean the contacts with DRY CLOTH.
Make sure the BB and battery contacts are all line up.
Close the cover.
Use the wall charger to charge the BB for 2+ hours.
DO NOT use the USB data cable to charge your Blackberry.
When the PC/Laptop/Mac go to power saving/SLEEP mode it will cut off the charge to the Blackberry.
Plug the power pack in a different wall socket and it the Blackberry charge.
Nov 11, 2009 | Cell Phones
Blackberry charge symbol appears but does not charge battery
are you using the charger that came with the BlackBerry?  cause sometimes that can make a difference.
otherwise you might just need to get a new charger.
and usually the wall chargers work the best.
i had a BlackBerry Pearl 8100 and the same thing happened to mine.
Aug 20, 2009 | RIM Blackberry Curve 8300
My BlackBerry won't charge, and I think it is related to the phone and not the charger. Any troubleshooting tips?
Its the problem with the battery. Soo try getting a new one. Its not the charger,
Good Luck!!
Aug 06, 2009 | RIM BlackBerry 8800
My blackberry is not working. I have charge it
my blackberry is not switching on. it is fully charged
Mar 08, 2009 | RIM BlackBerry Bold 9000 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
1,233 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
