Question about Kenmore 9296x Top Load Stacked Washer / Dryer
Kenmore stacked washer dryer code E9
I have a model 91801 per the operation instructions and on the machine inside the dryer door it is 417.9918010. we replaced the drive belt on the driyer drum and when we put it back togerher it ran for several hours over a 2 day period and now it shuts down after a couple of minutes and gives a display code of E9. The washer seems to work ok.
Got any ideas?
SOURCE: Kenmore Elite Oasis TL washer, stubborn Sd code
Found the problem. After removing the back panel, found some garments in the bottom of the surrounding clear plastic tub. These must have been periodically blocking the outflow area and triggering the Sd error code. Fixed it by opening the top components of the washer so I could see down into the surrounding tub from above. Fished out the garments with clothes hangar. Put everything back together and have done six loads with zero problems.
Posted on Mar 21, 2008
SOURCE: Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Posted on Oct 14, 2008
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
Posted on Nov 30, 2008
  • 113 Answers
SOURCE: Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at The gearcase replacement tutorial will put you in the right direction. Dave
Posted on Mar 03, 2009
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
How far can I vent this dryer?
Check your local building code per the instructions you received with the new machine. There is no 'standard' distance considering the government regulations and local conditions, where ever it is you call home, and please dont say.
Dec 12, 2011 | Kenmore 98702 Stacked Washer/Dryer
I have a kenmore stacked washer/dryer. It's a top
With the sympthoms your describing its sounds to me as if the timer is going to be the problem. IT could be a lid switch problem but since it does drain i can pretty much eliminate the lid switch,or even the motor and narrow it down to the timer.
Reply with the entire stack unit model number as found on a label inside of the DRYER door and i will give ya the part number for the washer timer.
Sep 17, 2011 | Kenmore Washing Machines
Want to stack my Kenmore HE4 Dryer on top of my Kenmore HE3t W/M
When you originally ordered the dryer, it should've come with a stacking kit that is compatible with the HE 3T or HE 4T washer. It is basically a foam piece that goes on each side of the washer, and then the dryer is connected to it from the side. If you do not have this piece, it should be available to order if you visit Just enter the model number from your dryer (inside the door frame) and it should pull up a parts list. Or just try searching for a stacking kit for Kenmore dryer. Hope this helps.
May 18, 2009 | Kenmore Elite HE4 Electric Dryer
Is there a stacking kit and what does it cinsist
Please post the model number of both your washer and dryer.
That information is on a sticker around the door of both. Then I can provide you specific information. OK?
Apr 20, 2009 | Kenmore Washing Machines
Kenmore 98702 Stacked Washer/Dryer. Dryer making clicking noise
There may be coins stuck inside the tumbling vanes in the drum.
Mar 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Where is the model #on my Kenmore stacked unit?
possible locations
Top- or front-loading washer-dryer combination unit
  • Inside the dryer door, on the door frame
  • On the top of the dryer
  • On the side of the washer, near the bottom, front
  • Under the washer lid
  • Feb 13, 2009 | Kenmore Washing Machines
    Kenmore 98702 Stacked Washer/Dryer Combo Model 417.98702890
    There is an EXTERNAL fuse on the back of the unit.
    Service manual is inside the machine's shell in plastic.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jan 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
    Dryer door
    I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
    Aug 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
    If it is stack from the factory (ie..came as one peice) you cant
    Jul 24, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Kenmore 9296x Top Load Stacked Washer / Dryer Logo
    67 people viewed this question
    Sal De
     Brian Main
    Brian Main
