pull machine out and make sure u remover the plug completley it is still live with the plug in and switched off throught the netural feed
at the back take off the botom white pannel made of plastic look in side pull the belt off the moter
there should be 2 10mm bolts remove these and tap the moter and it should slide out
remove the earth wire and the moter harness plug and pull the moter out it will go you might have to turn it this way and that once out there is two screws holding each brush remove and put in the new breushes replace the moter
to put the belt on there is two screws on the lid one each side behind a oval blanking cover these are hex head screws
once off put the belt on the moter pully first then on the drum pully and gide it on by hand turn the drum and the belt will spring on open the door and spin the drum by hand to make sure the belt is on correctley replace lid and back turn on power an try if this does not work the moter has gone try ebay i did for my hotpoint cheaper than trade on there
Was this helpful?
Yes
No
Popular Solutions for Hotpoint Aquarius WMA42 Front
dishwasher is going through wash cycle then stops, then pre wash and wash flash at the same time,...
(More)
dishwasher is going through wash cycle then stops, then pre wash and wash flash at the same time, everything stops, and when you open the machine the water has not drained away
How can I tell when it is operating as a half load? Washing machine WM56, 1100 washer, Hotpoint...
(More)
How can I tell when it is operating as a half load? Washing machine WM56, 1100 washer, Hotpoint There is a button on the front which when out shows a green flash on the button and when it is pressed in the green flash on the button does not show
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
