Question about Dell PowerEdge 1600SC Server
Can not access bois
Got a poweredge 1600sc server that powers on hang up at Checking SCsi device spinup>Also does not let me enter the bios menu at boot up.
Re: Can not access bois
My Dell 1600sc hung at bios screen. Progress bar qas about 10% . Problemed turned out to be a corrupted memory module - reved 3 out of 4 and tried to run worked and then process of elimination
Posted on Sep 22, 2012
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
It hangs there probably becuase one or more of the drives are dead or are almost there. Check and see the lights on the drives are falshing funny or too long or are yellow. If you find one of them that are that way, pull it out and then reboot.
See if that helps.
Posted on Nov 17, 2007
0 characters
3 Points
Scsi controller devices
Yes Doug. What is your problem with your Scsi controller device?
Feb 01, 2014 | Dell PowerEdge 1600SC Server
Is the HD SAS/SCSI/SATA on a raid controller?
If so you need to enter the RAID config (not the bios, but there will be a RAID config option during the boot process CTRL+M I believe.. but it will say on screen.) Then you need to set up the raid config, then initialise, then the drive will be detected for loading the OS.
Either that or the drive(s) shafted.
What sort of disks are you using?
Aug 20, 2010 | Dell PowerEdge 1600SC Server
Dell PowerEdege 1600SC not recognizing IO devices
Just go into the bios and insert the correct parameters. you shut it off before it could save the settings. Or hit fi on boot and it should take you into the bios and you cand sort it out in there. If you want an easy way, just do a system restore. Start,Programs, accesorys, system tools, system restore, just go back a day or two before you had that issue, and you should be good to go, good luck
Apr 12, 2009 | Dell PowerEdge 1600SC Server
I have lost the scsi drive on a dell 1600sc and would like to convert to sata. During boot up the sata controller is reconizing the 2 hard drives but, come but with "no primary drive found"
The best thing to do is reinstalling SCSI, SATA can only manage two disk per channel on this server, and the data transfer time is longer.
If you set SATA, check jumper settings, that is probably reason why you get no primary drive.
Also check bios settings , do hdd auto detect and save in bios if you want to use sata.
If instead you want to go back to SCSI, download the drivers from the link below.
Download page from Dell.
Mar 03, 2009 | Dell PowerEdge 1600SC Server
Need to powerup PowerEdge with out hitting the power Button!
ahhh ok, well in the bios of some machines their is an option to schedule a wakeup time for the PC, and you could also enable Wake On Lan and then wake up the PC remotely from a computer outside of the server room?
Feb 20, 2009 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server problem
I had the same thing happen in a 600SC about a month ago.
Replaced the memory, and it fixed the problem.
It did the same hang. Would run fine for any where from a hour to 3 hours, and then quit (hang). And I got the same message. Talk to them and it was a short in the memory module, so some times it would read the entire stick, other times it would "not see it", and that would lock the OS.
Sep 03, 2008 | Dell PowerEdge 1600SC Server
How to install win2003 server freshly on dell power edge 1600sc?
You'll need to load the SCSI hard drive controller driver.
Aug 06, 2008 | Dell PowerEdge 1600SC Server
Install windows xp pro
My is working , i have same dell server 1600 , i download the driver from LSI website here is the link
you just need u320 scsi driver for server 1600sc
download XP driver 32 bit it will work
Jul 04, 2008 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server Logo
484 people viewed this question
Top Dell Computer Servers Experts
Jax Planet
Jax Planet
Shawn DuRee
Edd nugent
Level 1 Expert
Are you a Dell Computer Server Expert? Answer questions, earn points and help others
