Question about Samsung Refrigerators
I have a Samsund SRS579NP both fridge and freezer not getting to right temperature. I don't think that the temp gauge is working properly. the fridge says that it is -1 degree but its deffiantly not that temp. Can anyone help
  • mrkroll Jul 12, 2009
    Thanks for the advise, but unfortunatley it did not work. So i had a so called fridge technician come out and find that it was low on gas, so he re gased the fridge checked that it was running. Said that it was all good and left.
    Two days later the fridge was warm again and temp displays where flashing, got him to come back and he couldn't find what was wrong with it, even though he seen that it was not running right. Said he would come back with his boss, but that hasn't happened it has been almost a week now since they originally came out. I have had no luck with this company due to they never return my phone calls and never come on time. Seems like I just wasted $240. Any advise would be greatly appreciated
    Sergeant:
  • 222 Answers
My first thought is dirty condenser coils (the coils on the bottom of the refrigerator behind the kick panel). You wouldn't believe how much impact a large accumulation of dust and lint on these coils can have on the efficiency and operation of a refrigerator. It's also one of the least expensive 'fixes'... It's FREE.
Remove the front kick panel and, with a flashlight, look at the horizontal coils under the refrigerator. If they are covered with a thick layer of dust and lint, you can almost be assured that this is the problem. They make tapered brushes specifically made for cleaning these coils, but any long slim brush that you can get between them to clean off the accumulation of dirt is better than nothing.
You can do a more thorough job if you pull the refrigerator out and remove the back panel to clean from both front and back. Be sure to unplug the refrigerator while you do this to avoid the condenser fan from coming on while you're working. It's always advisable to use a vacuum attachment to actually REMOVE the dust and lint from the bottom of the refrigerator rather than leaving it under there to be drawn back up into the coils very quickly after you've cleaned them off.
There's no specific definition of 'clean' coils, but my advise is to clean them as thoroughly as you can and be sure to clean off the small condenser fan as well.
Put the panels back in place and plug the refrigerator back in. This should do the trick. Dirty condensers can make you think your whole refrigerator just when ka-pooey when this easy (although somewhat dirty) task can make it run like new again.
Hope this helps.
Posted on Jun 28, 2009
Model #FGHC2331PF frigidaire. Controls were set for 35F fridge and 0F freezer, but when the fridge stopped the temps went up. They are now at 40F fridge and 5F freezer. Why?
Because nothing is perfect. As soon as the compressor stops running, the refrigerator will start to get warmer as the ambient temperatures will affect it. Then after a few degrees of temp rise, if thermostat is working properly, unit will kick on again to lower temps to preset level. And the cycle continues.
Apr 02, 2016 | Refrigerators
Freezer is working, but refrigerator side not cooling
Hi, you have two separate temperature senders one for freezer and one for fridge it sounds like the fridge temp gauge is not kicking in and needs to be replaced.
Dec 16, 2015 | Refrigerators
Why is freezer way too cold and fridge too warm when the temp display actually states the preferred temp?
Check the fan in the freezer section, its probably not working or turning too slow. Also check the fresh food cold adjustment its really just a door that gets adjusted, but it could be blocked with food, stuck or broken.
Sep 01, 2014 | Refrigerators
Magic chef french door fridge only cools on the bottom
If you charged the unit yourself the only thing I can think of is that you did not charge it properly. Refrigerators are not like AC units - the amount of charge, measured in ounces is very critical. You have to be right on the money lest it not cool properly.
If you have access to gauges and you are using the AC refrigerant normally used for cars, the pressure at ambient room temperature of 78 degrees should be around zero. Let the unit run for about thirty minutes to stabilize pressures and then do the reading. If room temp is higher than 78, then pressure can be a tad higher but no more than oupounds.
If no gauges, then allow unit to stabilize and then observe the temperature and condition of the suction line to the compressor. On a properly functioning unit the line should be cold to the touch and maybe sweating or beading. If it is warm to the touch you are low on refrigerant - add small amounts slowly till pipe cools. If you have frost forming on the pipe going to compressor the unit is overfilled and you have to bleed it slowly till it is cold and wet, not covered with frost.
Insufficient cooling is also caused by a improperly working freezer defrost mechanism whereby ice accumulates in freezer compartment. Here the culprit is either the defrost timer and or defrost heater element.
Nov 24, 2013 | Magic Chef Refrigerators
Will not make ice, freezer temp is high, can not control the temp
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 31, 2010 | Frigidaire PHS39EHSS Stainless Steel Side...
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
Fridge warm, freezer working, pump working. where
Either the thermostate is defective or refrigerent blocked or leaked or the relay is not functioning properly. Only on inspection of the above parts could pronounce the right remedy.
Jul 06, 2009 | Refrigerators
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Refrigerators Logo
286 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
