Question about HP PSC 1410 All-In-One InkJet Printer
Cant scan from printer to pc - HP PSC 1410 All-In-One InkJet Printer
  • 56 Answers
Click on start
:then click on run
:type in msconfig
:click on statup tab
:find hp digital imaging monitor
:select the check box next to this item
:click on apply then click on close
;click ook if acess is denied message comes up ,it wont prevent u frm printing
:issue will be resolved
Posted on Jun 28, 2009
I have a canon pixma MP495, can't get it to scan. I've installed the driver from the canon website, but still no luck scanning. it worked before not too long ago, but now it won't
if you can print but cant scan, your usb is ok. so its either your pc or your scanner machine has the problem. to isolate the scanner machine if it has the problem, try to scan with the lid or scanner cover is open. observe if the "stick" (with the lights and belt attach to it) can move around the glass (left or right or up and down, depends on how you look at it). if its stuck in one side, then you have a mechanical problem. otherwise, check for your pc for some problem. you can check it by installing the printer driver to a 2nd computer and see if that pc can scan or not. if that 2nd pc cant scan too, definitely your printer is defective
Sep 21, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
Downloading application list - cant retreive application
If your pc tels you its downloading application, have a look a your printer drivers, your usb cable connecting your pc to printer and or the data cable inside the scanner might have gone faulty
Apr 18, 2013 | Lexmark X5470 All-In-One InkJet Printer
RX425 wont scan
try installing the printer with it original driver it will work
Jan 25, 2013 | Epson Stylus RX425 Multifunction...
How come my pc cant link to scan doc???? this is an office pc. my pc at 1st can link to this canon IRC3220N , it can photostat can scan from the canon to pc into scan doc file. but for right now my pc...
try to reinstall the driver s for the printer/scanner ...and see if the issue is solved.....Another thing ....if the scanner is used by multiple computers you have to give the scanning command from the computer ...and not from the scanner itself...This way you will be able to import the scan result into the library of the program that drives it ..
another thing that may happen is the link to be broke ...so ..get to the fax and printers in the start menu ...and open it ..and redo the link ..by scanning for printers and choose it again from the list ..(by name ) ..and make it the default printer/scanner..
Jul 05, 2011 | Office Equipment & Supplies
MY PRINTER SAYS CANT FIND PC?WHATS THAT?
You need the correct drivers installed. Go to hp.com. /Drivers/enter your printer model/check the OS you are using/select the scanning drivers
Jan 08, 2010 | HP LaserJet 2840 Printer
I press scan but nothing happens I scan on cannon Mp 160 and I cant scan with my pc
Make sure the scanner is connected to your laptop/PC before you press 'scan' and is turned on.
Pressing the scan option will start Canan's software MP Navigator for scanning. You can also start MP Navigator on your PC and then start scanning directly from your program or from the printer button.
Dec 31, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I cant scan from my kodak all in one printerto my
Try system restore to a day before your problems started and then you should be right.
Jun 03, 2009 | Kodak 5500 ALL-IN-ONE PRINTER
Cant see the PC in the scan selection
Has your printer share been changed to the new workgroup in the driver section?
Jul 05, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
I cant scan
You have to connect the mfc directly to a USB port of your computer. DO NOT use a hub.
The mfc uses the XP buil-in scan driver.
Did you install the whole mfl-pro suite? Use paperport to do scanning from your pc.
Jan 23, 2008 | Brother MFC 210C All-In-One InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
