Question about Hotpoint First Edition FEW12 Front Load Washer
Belt has come of my machine FEW12 - Hotpoint First Edition FEW12 Front Load Washer
  • 82 Answers
Check the moter is not lose and the pully is not lose if these are fine put the belt on the moter first then the pully on the drum guide it one and spin the pully slowley and it should pop on MAKE SURE POWER IS OFF AND PLUG IS REMOVED THE MACHINE IS STILL LIVE IF SWITCH OFF AT PLUG AND STILL PLUGED IN
Posted on Jun 28, 2009
  • craig thorne Jun 28, 2009
    check the moter is not lose and the pully is not lose if these are fine put the belt on the moter first then the pully on the drum guide it one and spin the pully slowley and it should pop on MAKE SURE POWER IS OFF AND PLUG IS REMOVED THE MACHINE IS STILL LIVE IF SWITCH OFF AT PLUG AND STILL PLUGED IN
REplaced belt ok but pulleys look out of alignment - any remedy?
You need to disassemble parts and then reassemble them properly.use greese oil for better performance
Mar 12, 2011 | Hotpoint First Edition FEW12 Front Load...
The drum is not going round and there is a whurring noise
This is the classic symptom of a broken belt. The whirring sound is the motor running with no belt. If you want more info, please let me know.
Charlie
Feb 25, 2011 | Hotpoint First Edition FEW12 Front Load...
How do i get the belt back on on a hotpoint FEW12
Remove lower rear panel of washer.
With the help of someone to hold it, tilt the washer forwards away from you at the rear.
Fit belt round motor pulley first, and slowly feed it round drum pulley, turning the pulley at the same time.
It will be very tight, so watch your fingers, just keep on going, until you get the belt on all the way round the pulley.
Mar 15, 2010 | Hotpoint First Edition FEW12 Front Load...
Drive belt came off spindle on Hotpoint First Edition Washing Machine.Have tried to replace but back of machine does not remove, just a small access hole. How can I refit a new belt please??? John Bennett...
Remove rear panel, remove top cover,.tilt washer forwards, get someone to hold it for you, and fit belt round motor pulley first, then start feeding it round drum pulley, easing drum round at same time, it will be tight, so watch you fingers,
Please rate my solution.
Thanks.
Sep 13, 2009 | Hotpoint First Edition FEW12 Front Load...
Few12 will not spin after washing, any ideas
Had the same problem. Removed the kick plate at front and unscrewed filter. In the filter recess I found a cotton wool bud. Appeared to have stopped the blade like fan spinning which appears to push the water into the drain hose. Works perfectly now.
Aug 19, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint FEW12 washing machine chews up clothes
If you check the door sal and there is any play in it then it needs replacing. Mine had two saggy indent bits and needed changing..no more ripped clothes
Apr 10, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint first edition takes in water but does not wash
Could possibly be a broken drive belt to the motor or motor brushes may need replacing.
Oct 28, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint first edition few12 wont fill
hiya
if your machine wont fill it will more than likely be a faulty inlet valve.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Jul 07, 2008 | Hotpoint First Edition FEW12 Front Load...
Machine does not spin ath the normal speed
you got a loose belt or a brake pad stuked, any way gonna need a tech, in this model is a easy job for a tech, but a dificult one for a regular peole...good luck
Aug 05, 2006 | Hotpoint First Edition FEW12 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
140 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
