Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
NO SIM MODE
My fone is saying NO SIM MODE, ive reset my fone ive turned it off hundreds of times cleaned the sim everything but it still says no sim node, how do i resolve the problem? Please help!!
Hi my Samsung geino touch is saying no SIM mode, i've taken the battery & SIM out several times but it still says the same, any help?
Posted on May 16, 2011
Samung tocco lite payg on 02 brand new, inserted my old 02 payg sim card and says no sim mode, have tried my 02 sim card out of my iphone and says the same thing, im presuming its a phone issue and is going back to carphone warehouse tomorrow unless anyone has any ideas, i would welcome any suggestions.............
Posted on Aug 09, 2009
  • 390 Answers
Hi
go to communications and change the phone conection from the Airplane mode to the Phone mode and things should get back to normal
hope this helped
cheers
pls rate the solution if it was any
Posted on Jun 28, 2009
  • trishaisfab Jan 11, 2011
    Help touch screen wont work same message !!!
    New Friend:
I had the same problem!! Here are the steps:
  1. Go to menu!
  2. Choose "Settings"
  3. Go to Network
  4. Go to "Network Mode"
  5. Select the network you are using!
Hope this was helpful!!! :)
Posted on Jan 14, 2013
  • Barry Erick Sep 14, 2013
    I had one of the 3 contacts for the sim moved, using a tool I had for my previous work ( a very tiny spring took adjustment hook tool, I was able to move it back in place and the phone worked again.
    Habit-Forming:
    Scholar:
  • 40 Answers
Try to use different sim on your mobile. if that sim is working then problem is with your sim card. and also use your current sim on other mobile. and if sim is not working then problem with your sim other wise problem with your network setting or sim slot . now if your current sim working on other mobile then do one thing reset all your mobile setting and then turn off your mobile and then again turn on your mobile. here is how to unlock sim card.
http://mobile-cellphones.blogspot.com/2016/06/android-smartphone-sim-unlocking-details.html
Posted on Nov 29, 2017
    Problem Solver:
  • 14 Answers
Barry that sounds about right . Anyone like me also should check the little copper pins to see if they are not sitting right. Some phones are harder to get access to. Some are really easy. For phones that are hard to get access to I would use a sowing needle to get under you silver sim holder to get them back into place. And for anyone using multi sims DON'T they bend the phones pins and in some cases cost a lot of money. I hope this helps !! :-)
Posted on Sep 24, 2014
Jailbroken/bricked Iphone w/tmobile sim card
If the Iphone works, all you have to do is reinstall Itunes.
Oct 07, 2008 | Apple iPhone Smartphone
How can i remove fone freeze on samsung s8300
If you unfreeze your mobile means this problem will be solved so get the unfreeze code for your samsung s8300 model mobile here Onlinegsmunlock.com , it gives the best instructions to get your mobile as unfreezed........
Dec 12, 2011 | Samsung S8300 Ultra Touch platinium-red...
My nokia says sim card not valid and off line mode
Try sim on another working fone, if it works, then your fone has a problem. if it doesn't, then your sim is the problem.
Feb 28, 2010 | Nokia 5800 XpressMusic Smartphone
No service
try to update ur fone. with sony ericsson software.
Jul 25, 2009 | Samsung Blackjack SGH-I607 Smartphone
Enter simcard problem
why dont you reset all of your settings go to wiki.sidekick.com they explain everything to do there  hope this was useful :)
Nov 13, 2008 | T-Mobile Sidekick
Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
Nov 05, 2008 | Nokia e65 Cellular Phone
Nokia n73
Look, your phone don't recognize the card try to put another card, if it won't help clean the place of the sim card with a tooth brush its probably dirt.
Jun 29, 2008 | Nokia N73 Cellular Phone
Sim lock
you need to put back the original sim card in the phone and do a master reset.....in the phone settings.....
menu/settings/intial setup/master reset - 000000 security default code
Jan 06, 2008 | Nokia 1600 Cellular Phone
Unlock samsung sgh e250 to any network
when i reset my sgh e250i and when it power on it not shows the network of my any sim card and imei become 000000000000
Nov 07, 2007 | Cell Phones
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
15,508 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
