I have removed and put battery in again to no avail ! new blackberry
Try this method
2. You need to install a BlackBerry OS file that is
specific to your device. The original version, as supplied by the
carrier, is the safe choice, but you can use any model specific
version. This is not supplied on your BlackBerry CD, Ref: 3 links to BlackBerry's download pages.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
We are about to venture into the bowls of the beast. Windows is not
suitable for this job, we are going to invoke the Command line
interface with an option switch.
Windows XP: Start / Run... / Command
Windows Vista: Start / Command (type this into 'start search')
