Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Hard start or won't start
I have the husqvarna YTH20K46 lawn tractor, purchased in 2007 from Lowe's. The problem appears to be intermitant. I have changed the fuel filter, spark plug and cleaned the fuel bowl. After several mowings, the problem of not starting comes back. I changed the fuel filter, spark plug and cleaned the fuel bowl again. The tractor ran good for a few mowings, The next time I went to use it, the engine would not start. It seems to be a carburetor fuel issue. Fuel is flowing good to the carburetor but I after cranking the engine and it did not start I took the fuel bowl off and did not have much fuel in it. I took the fuel line off at the carburetor and the gas was flowing good. Note: the tractor is kept in the garage. cleaned after each use and oil changed on a regular basis.
  • 513 Answers
The float in the fuel bowl might be getting stuck what you can do is push & pull on float to see if it flows if not the replace the float if i can help further e-mail me wade @ wadembly@aol.com
Posted on Jun 28, 2009
Husqvarna YTH20K46 Lawn Tractor Will not Crank due to battery issue
Check the start fuse, under dash and back side of engine.
Jun 02, 2012 | Husqvarna Garden
Connected a battery wrong and now Husqvarna YTH20K46 will not crank
look for a blown fuse there taped to the harness
I have a yth20k46 and when I turn the switch it won't turn over. I replaced the battery and spark plugs. what might be the problem
I also have a YTH20K46. During last mow (last week), I tried to turn off mower and would not turn off by key. I had to put it down to choke and then stand up. It created a backfire. Today I went to start it, now won't start. It does not turn over. Hour meter has no power. Tested battery & solenoid. Power to both. Key switch works fine. Any suggestions? Just had it serviced a few months ago. Oil, gas and all other things seem fine. Checked wiring, seems fine. Nothing melted or cut. Please help!
May 23, 2012 | Husqvarna Garden
The drive belt on my husqvarna yth20k46 is off at the pulley above the transmission. How do I get it back on? Do I have to remove the nut at the transmission shaft?
I would remove the nut and pulley. Get belt top of pulley. Start the edge of belt in broove on pully and run it around. You get easyer belt in pulley and install it. May have pull little against spring.
Mar 31, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Drive (motion) belt has come off the rear pulley twice in a month
husqvarna yth20k46
drive belt came off
fix
transmission boltes were not installed
replaced fix problem
Jul 16, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
670 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
