The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. I can't say it's 100% the problem because I can't actually look at the tv over the internet. If by chance the TV is still under warranty, go that route. If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
My rear projection tv will turn on when i push the power button, and all the power lights turn on,...
(More)
My rear projection tv will turn on when i push the power button, and all the power lights turn on, but then it turns off a minute or two later. Im not sure if the power lights stay on after it has already turned off, but this keeps happening. I need to know if this is a fixable issue, or if I should just go and get a whole new tv. Its about 3-4 years old.
Does this television have built in digital receiver? I want to hook up antenna to get local...
(More)
Does this television have built in digital receiver? I want to hook up antenna to get local channels...have canceled satellite service.
My lg42lc2d is 3 years old. recently the screen goes black after a few seconds on switching the set...
(More)
My lg42lc2d is 3 years old. recently the screen goes black after a few seconds on switching the set to on.Sound is perfect. Technician informs the whole screen needs to be replaced as I understands some lamp that lights up the screen may have died and if one is bad then the whole series have to replaced. That seems strange and replacing the screen would cost a lot of money and may be cheaper to buy a new TV
my lg lcd tv has had a short circuit when i was switching on and off. i had this poping sound and i...
(More)
my lg lcd tv has had a short circuit when i was switching on and off. i had this poping sound and i new its gone. can it be repaired?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
