Question about KitchenAid KEYS750LQ Electric Dryer
Motor in old dryer wasn't spinning. Often needed manual kickstart. Pulled motor out. Cleaned out dust and debris. Re-assembled it (a few times). Was confident this would solve the problem. The motor looks in good order but still not spinning. Have I upset the polarity or something? Damn, all those hours I was fiddling around...for no reward! Is it still serviceable? Any tips troubleshooters? Thanks in anticipation. Peter.
    Genius:
  • 1,122 Answers
No,they just wear out,the model number is inside the dryer door,you can try a used appliance store or maybe find one on ebay cheap-mike
Posted on Jun 28, 2009
LG Washer/Dryer Combo not spinning
If you can make the motor spin a few revolution by manual intervention, then the issue is most likely a faulty motor 'start' capacitor which is located near the motor: this replacement involves a dangerous MAIN AC VOLTAGE device and I would advice getting a qualified technician to check/repair your dryer.
Hope it helps.
Apr 06, 2014 | LG WM-2277HW Front Load Washer
I have a frigidare dryer 5-6 years old. Recently, started smelling like something electrical is burning. If I hold down the start button the motor will turn the drum slowly and the burning smell returns....
Check for vent blockages! Overheating may be a serious issue and fire hazzard. A slow moving drum could mean a bad traction belt, jammed mechanical part or the motor is not spinning at a proper RPM which may indicate motor damage also. The electrical burning is a serious issue also and a fire hazzard. Dryers need periodical cleaning to remove excess lint, dust and debris. Lack of cleaning causes the dryer to work harder and run hotter. Excessive heat shortens the life of many parts such as belts, bearings, electronics, wiring, etc...
Sep 21, 2012 | Dryers
Heat shuts off after a few minutes
Clothes Dryer Repair and Common Problems - Loud Noises, Overheating and Not Spinning84rate or flag this page
By expectus
1342481_f260.jpgBasic inside of a dryer, picture from hometips.comClothes Dryers Problems
I decided to start this hub due to the amount of problems I have been having with my current clothes dryer , and what I went through to fix a few problems I had with my dryer including a broken tumbler belt and loose tumbler drum.
So the basic design of a dryer hasn't really changed much and most people will find that there dryer will last a long time and wont generally need a complete upgrade and a few fixes every now and then will keep it running for a very long time.
So depending on the design of your dryer it will look pretty much similar to the picture on the left and contain all the main components. The main parts that usually require fixes or maintenance include
- Drum belt and Rollers
- Motor and motor bearings
- Blower , heater and heat sensors
1342506_f260.jpgSafety and Cleaning
The first thing is to make sure everything is unplugged before starting to tinker inside your dryer, and depending on the style of your dryer pull the back door or hatch off slowly so you dont accidentally rip off the wires.
Some old dryers also have very loose tumbler drums so when opening the back door hold the drum in place to stop it from banging around inside the dryer compartment.
Cleaning
Cleaning is very important for your dryer, and after opening up my clothes dryer after about 10 years of use I could tell it really needed some regular maintenance and cleaning.
There was an amazing layer of dust covering everything and the actual box compartment was dull of dust and little bits of sand and dust. For newer dryers this may be less of a problem but sometimes if you hear your drum spinning a bit loudly it may just be a large layer of dust and dirt.
Common Problems
1. The Clothes Dryer Drum is not spinning or not spinning correctly ( loud noises and screeching sounds)
- The most common reason for the dryer drum to stop spinning is if your drum belt has snapped or has been worn down completely. This is an easy fix and simply involves buying a replacement belt and feeding it through the pulleys and on the roller and then back around the middle of the drum.
- The rollers could have worm out causing the drum to spin in a bumpy and noisy manner , these are the little circle shaped objects your dryer actually sites and can usually be replaced depending on how old your dryer is. The pulleys could also be broken causing problems.
- The motor could have died after many years of use if the drum is not moving at all and if it is moving the motor bearing could be off causing to spin around very roughly and sometimes scratch against the sides of the dryer compartment.
- Noises coming from the dryer when its plugged in and spinning could also be due to a huge amount of dust built up around the dryer drum. Sometimes cleaning out the inside of your dryer and returning the drum to the correct position can fix this problem.
Screeching noises are not a good sign and sometimes its a sign that you drum is slowly cutting into the sides of your dryer which could permanently put your dryer out of use if its continues.
1342561_f260.jpgDigital multimeter, look for resistance settings or OHMS symbolClothes Dryer Heat Problems
Another common problem is that your dryer will either run too hot or too cold , and sometimes take many cycles to simply dry a few items.A useful device that could in handy for testing that each component is working is a simple multimeter or volt meter you can buy from an electronics store.
The way you test the functionality of each component is to get your multimeter or voltmeter and put on the lowest Resistance setting,
Temperature Switch - Leads on switch terminal should read zero or infinity
same for thermostat, heating coils and timer testing.
The most causes of these sorts of issues are
- The temperature sensors could be dead or fried and need replacing, they look like little silver dollars and are usually located under the drum.
- The exhaust outlet could be clogged with dust and dirt causing your dryer to run hotter than the temperature you set it at.
- thermostat or heating coils could be defective and need replacement
- There could also be problems with the timer, if the timer is not working correctly this may cause the heater and blower to remain inactive.
- The fuse is dead and needs to be replaced.
Dead Dryer Alternatives417uoqjhrbl._sl75_.jpgPolder Two-Tier Free Standing Clothes Drying Rack with Mesh Garment DryerAmazon Price: $21.52
List Price: $29.99410qipqvuwl._sl75_.jpgIndoor Clothes Drier Y Airer Rack, 79'Amazon Price: $33.00
List Price: $51.9931c6s6bhkol._sl75_.jpgSteel TAssembly 4 pcAmazon Price: $24.95
List Price: $33.99Dryer totally Dead wont Start
So your dryer wont start at all this can be caused by the failure of one or more components and is sometimes hard to pin point.
The most common are below apart from problems relating to your power mains
  • Timer or thermostat
  • Terminal block
  • Start switch
If anyone has any problems with there old simpson dryer I may be able to help you out as I spent a lot of time tinkering with my old simpsons clothes dryers.
Jan 11, 2012 | Dryers
Smells like hair burning
By expectus
Cleaning
Common Problems
  • Terminal block
  • Start switch
Jan 11, 2012 | Estate Dryers
My dryer is making a buzzing sound when trying to turn it on. Not working. Cleaned lint in machine. Also made sure the door is closed. This happened a few weeks ago, didn't work for a few days and then...
the buzzing noise is the motor trying to start try a test leave the door open with one hand press the door switch with other hand spin the drum at the same time have someone press the start button if your dryer starts then and when it is cool it is the motor replace the motor
Apr 05, 2010 | Dryers
Hey, I have a Whirlpool Hotpoint electric dryer that is broken. The drum will not spin. I can hear the motor engage like its trying to spin. It will do this about three times (start/stop cycle) then...
remove belt from motor so there is no drag on motor or pulley,then spin motor shaft and pulley by hand,it should spin freely and coast to a stop,if it is hard to spin,the bearings are dried out and normally its new motor time,you can try removing motor and soaking bearings in a solvent and re-oiling,but that usually doesn't do it
Jan 16, 2010 | Washing Machines
Heater fan dont work all the time on my 94 volvo 960
After some years, the the filters (made of foam) in the HVAC system can become dry-rotted. Debris from the rotted foam, as well as dust, can accumulate in various places within the system. Unfortunately, the motor housing of the blower is one place in which the dust and debris accumulate very well. To fix the problem, you have to remove the cover from the blower, and vacuum clean it. The blower is behind the glove box, on the lower right side.
A word of caution: The fan cage (which looks like a gerbil wheel) can become brittle, over the years. After cleaning out the blower motor, the blower will be able to freely spin at full speed, again. This may be too much for an old brittle fan. If your old blower can't take the force of spinning at full speed, you will hear it break apart inside its chamber. I discovered this, the hard way. After cleaning the dust and debris from my Volvo's blower motor, the blower spun at full speed and the fan broke apart. So, I had to buy and install a whole new blower.
Dec 13, 2009 | 1994 Volvo 960
My whirlpool electric dryer smells hot.
generally if the uint shuts off from overheating and then will not restart for a 10-20 min period of time usually a sign htat hte motor is overheating and needs repalcing
Mar 31, 2009 | Whirlpool LER5636P Electric Dryer
KitchenAid KEYS750LQ Electric Dryer Logo
81 people viewed this question
Top KitchenAid Dryers Experts
Tim Whalen
Oloyede Monsuru
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
