Question about SanDisk Sansa e250 MP3 Player
Won't charge new battery? - SanDisk Sansa e250 MP3 Player
How to tell if a105-s4074 satellite battery is bad
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 28, 2012 | Toshiba Satellite A105-S4074 Notebook
My device won't charge
This situation sometimes occurs when the batteries get overcharged. Use the phone for a day and then attempt to charge. If it still won't charge, remove the battery for about a minute. Then re-install the battery and attempt to charge. If that doesn't clear the problem, you may need to get a new battery.
Mar 03, 2012 | Motorola Mobility T505 Handsfree...
I reinstalled XP on IBM T41, now battery won't charge. Could this be Driver Problem
Sounds like you need a new battery.
It's not just a battery in a case, it also has a small circuit board inside to control the charging etc, if that's faulty it won't charge, or if it has dead cells in it won't charge.
Feb 08, 2012 | IBM ThinkPad T41 Notebook
Uniden battery will not charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Feb 04, 2012 | Uniden Cordless Phone
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
Sony vaio vgn-nr285E battery won't hold a charge
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
Why its battery quickly drains
Jul 18, 2011 | Motorola Mobility C168 Cellular Phone
Nokia 5130c-2 always charging but when i remove charger battery is low give me solution
Hello.
these symptoms means that a new battery is required.
the phone's battery is exhausted after a long time of use, replace the battery and the problem is solved.
Best Regards.
Jun 03, 2011 | Nokia 5130 Cellular Phone
1990 plymouth colt, new alternator, still won,t charge. what tells alternator to charge battery?
Have you also had the battery checked? If the battery is bad, then it won't charge. All of the terminals need to be checked for corrosion. All wires must be secured properly. Check to see if the ground cable is properly attached to the frame of the vehicle.
May 03, 2011 | Ovens
SanDisk Sansa e250 MP3 Player Logo
48 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
