Question about Pentax Optio 60 Digital Camera
My card is locked. what shall I do pentax optio
My card is locked. what shall I do. the camara is pentax optio 60 digital
thanks
  • Ty Price May 11, 2010
    Do you mean the card is locked in the camera and you can't remove it or is is simply that the lock buttton on the side of the card is in the lock position?
  • mutleysdoo May 11, 2010
    can u read the photos on there it it just wont store any new ones. it may have a data protect feature turned on via the menu in the camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Aug 23, 2012
bestdarngood
  • 3037 Answers
SOURCE: Unlocking memory card
http://www.pentax.de/downloads/photo/uk/Optio%2060/Optio60_Manual_web.pdf
pg 17 at the bottom shows how to unlock the card, but it is simple, take out the memory card and on the side of it will be a little tab which can slide, slide it off the lock position and it should work
Posted on Mar 18, 2008
lock123
  • 6831 Answers
SOURCE: How to unlock card in pentax optio Says Card
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 22, 2010
Steve5
  • 423 Answers
SOURCE: Pentax Optio 60
Largest card for the Optio 60 is 2GB. The camera is not able to take 4GB and larger SDHC type cards. If I answered the question to your satisfaction, don't forget to rate it. Thanks
Posted on Mar 20, 2009
SOURCE: Pentax Optio M30 - screen
the sd card has a lock on it, switch it in the up position. this will take it out of lock. good luck
Posted on Apr 11, 2009
leecom72
  • 4806 Answers
SOURCE: keep getting card locked on my display screen
Hi there.
Face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Please post back if you need any additional advice.
Good luck and thanks for choosing FixYa!!
Posted on May 29, 2009
TENGO UNA CAMARA PENTAX OPTIO E-35 Y AL ENCENDERLA ME MUESTRA UN CANDADO QUE NO ME DEJA USAR EL MENU, QUISIERA ME DIJERA QUE DEBO HACER PARA DESBLOQUEARLA
Its possible that your have locked the SD card; remove the memory card from the camera and make sure that the physical switch is in the "UNLOCK" (up) position. See photo example...
Keep us updated.
May 09, 2011 | Pentax Optio T20 Digital Camera
When ever I turn on the camera, the display shows "card locked". I can hit the > button and it appears to unlock it, since pictures now show up. But, whenever I try to do anything else it locks back...
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 11, 2009 | Pentax Optio 60 Digital Camera
Digetal carara card lack
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 19, 2009 | Pentax Optio S5i Digital Camera
When Iturn it on the screen go blank and say card lack it is a pentax Optio S5I digetal camara
How do i delete pictures when card is full ? help!!!!.
Hi there.
If you have copied the picture to your computer or you don't want the pictures that are on it, just use the camera's menu to format the card, that will delete all the pictures on it and it will be ready for use with the camera again.
May 29, 2009 | Pentax Optio 60 Digital Camera
Keep getting card locked on my display screen
Hi there.
Pentax Optio 60
Feb 26, 2009 | Pentax Optio 60 Digital Camera
I want to pentax service centre address located at Kolkata
why don't you try www.247servicecenterinfo.com, they have listing of all ipod camara centers in india.
Feb 21, 2009 | Pentax Optio 60 Digital Camera
Mar 18, 2008 | Pentax Optio M10 Digital Camera
Optio 60 Card Locked
if it says card locked. take out your memmry card on the side of it should be a white little strip you probably swtiched it to locked! you can unlock it by clicking it up!!!
Jun 23, 2007 | Pentax Optio 60 Digital Camera
Pentax Optio 60 Digital Camera Logo
261 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
