Question about Toshiba Gigabeat MEG201 MP3 Player
Toshiba Gigabeat-U MP3 Player suffering "USB ERROR #203"
I've been using by Gigabeat for months now without problems, but after connecting it to my computer tonight, it suddenly has problems syncing anything. Every time I try, it immediately cuts out, the screen reads "USB ERROR #203," and the player isn't aware that the USB is still connected.
Even if I'm not syncing anything and it's just recharging, the error has a tendency to surface.What do I do?
  • 44 Answers
Try reinstalling any software that come with it.
try a different usb cable.
try different usb ports.
Posted on Jun 28, 2009
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
Gigabeat room fails to recognize my Gigabeat
transfering is not a a problem its a player problem have  you ever format your mp3 player?
Dec 16, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
USB Connection Problem
I have the same problem. If you have a large library try letting it stay hooked up for a long time. It seems like it is taking inventory of device then it should work after a while. Sometimes this works. Sometimes I have to unplug then try again in a few minutes.
Aug 31, 2008 | Toshiba gigabeat MES60VK Digital Media...
I cannot sync more than three songs at a time on my toshiba gigabeat without it saying USB Error [#-203]
Make sure the hold or lock switch is not engaged - try resyncing
if still no, then go to Start --> Control Panel --> System --> Hardware --> Device Manager --> USB Controllers - look for a yellow exclamation, and right click it, update driver
Jun 19, 2008 | Toshiba Audio Players & Recorders
File transfer Problem
Ok, I figured out a solution on my own.
Remarkably simple - all I did was reformat the player again and then reinstall windows media player.
Although in my travels I came across an article which may help users with a similar problem: http://support.microsoft.com/kb/911091/en-us#appliesto
Apr 20, 2008 | Toshiba gigabeat S MP3 Player
Toshiba Gigabeat S
im ahving an extremely simmilat problem but my gigabeat is connecting diisconecting (repeat) and my computer is not doing anything
Apr 16, 2008 | Toshiba gigabeat S MP3 Player
System error on toshiba 40gb mp3 player
Try reformating the player using gigabeat format program see pg.52 owner's manual than restore the firmware data in the player see pg.51
Feb 17, 2008 | Toshiba Gigabeat F40 40 GB MP3 Player
Toshiba gigabeat 30gb-multimedia player
Sometimes when the Gigabeat's battery dies out fully with no life in it, you cannot recharge it via USB. You must use the AC connection to charge it. If you do not have the original charger, you can use a Sony PSP charger.
Nov 20, 2007 | Toshiba gigabeat S MP3 Player
Please help
Toshiba Gigabeat support is 1-877-250-8595
Sep 19, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Battery Problem
Try your luck charging thro' USB port from a PC
Aug 26, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat MEG201 MP3 Player Logo
281 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
