No Stereo output from front speakers. No Stereo output from front preamp out. No output from headphone jack. All other speakers and preamps-out work very well without any noise. I need to know in which section of the board there might be a problem. Regards.
SOURCE: I am trying to use
at the back of Marantz receiver try to find and output connection of 12 volts,if not you must open your receiver then connect the 12 volts at the output voltage transformer..
hope this may help
DONT FORGET TO RATE:
Regards,
VOTIT
SOURCE: How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
SOURCE: Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
SOURCE: how do i attatch preamp to marantz sr9200 for phono
If you are talking about a phono preamp, take the output rca cables from the turntable, "red and white" plug it into the preamp input, "labled" next take a red and white cable wire male ends, "3 to 6" feet long, and plug the one end in the output of the preamp, "labled" and finally plug the remainder into the AUX input of the Marantz receiver matching the colour codes so the left and right channels don't get mixed up, you now should be good to go.
