Question about RCA RT2360 System
Rca rt2360 When I power it on it says overload and shut back off
Re: rca rt2360
Possible short in output amplifier darlington transistors. Check cable connections first, but if that doesn't help, it is likely a amplifier problem
Posted on Jan 16, 2008
0 characters
3 Points
I have a RCA DVD Home theater system and I plug it in and the blue standby light comes on, but when I push it or other buttons on the unit, it just powers off and then won't turn turn back on at all....
I am having the same problem...i plug it in the standby light xomes on but i press the power button and nothing happens...mine is a rca rtd315wr model
Sep 03, 2011 | RCA RT2360 System
When i turn it on it clicks and it says overload then shuts off
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 09, 2011 | RCA RT2360 System
I need to replace the speakers for my RT2360 System, can you recommend a source for this?
rca is no longer the same rca that built that stereo ---as a result there arent parts available--i work for an rca servicecenter --all thats available are tv parts --i recommend shopping for generic replacements at either mcm electronics or parts express --both have thorough websites and comparable replacements
Sep 03, 2010 | RCA RT2360 System
RCA RT2770 receiver won't turn on
it is a high power switch to get it fixed it will cost about 100 $
Jul 08, 2008 | RCA RT2360 System
Circuit problems. Take to pro/tech for check out
Nov 11, 2007 | RCA RT2360 System
RCA RT2360 System won t Turn on what to do
its probably the transformer in the unit has blown out
you will need to try and find a replacement
Oct 25, 2007 | RCA RT2360 System
Home Theatre System
Check the speaker wires going to the back of the unit. Any stray wires that cross can and will cause overloads to the audio output IC's. Make sure the wire strands are twisted tightly and then inserted into the spring clips.
Feb 27, 2007 | RCA RT2360 System
open it up then plug it in. when you press the power button see if one of the large white boxes (there are six in a row) lights up red.
Sep 29, 2006 | RCA RT2360 System
RCA RT2360 System Logo
169 people viewed this question
Top RCA Home Theater Systems Experts
Ismael Lopez
Level 1 Expert
Are you a RCA Home Theater System Expert? Answer questions, earn points and help others
