Question about RCA Lyra RD2854 40 GB MP3 Player
The problem is...
When i turn the mp3 player on it says that the it failed to load. Reset unit to resume operation.
update lyraHD system files ifif problem persists... what do i do to fix the problem???
Re: the problem is... - RCA Lyra RD2854 40 GB MP3 Player MP3 & Digital Media Players
DId u figure out how to solve it ?
Posted on Dec 01, 2007
0 characters
3 Points
I have a sansa mp3 e280 and when i turn it on it says load image failed
i am assuming the image file means the boot loader, the problem is a bad flash can cause this mostly. also note that if you tried to update the firmware you will have to either re flash it. or send to factory for repair. better to not update new components.firmware if this is the case, they often become bricked units.
Dec 21, 2009 | SanDisk Sansa E280 MP3 Player
Plz help...
A firmware update. Same happens to my friend's unit yp-u2(x) a 512 mb model.
1. Download and install firmware updater.(manufacturer's support site)just key in model number and type.
2. Run updater, press and hold play button until its been detected fully by the updater.
3. Check the format box(My friend's unit firmware ver is to something when updated).
4. Hit the update button or something like that. do not detached the unit until its done. Unmount the unit using unmount method "Safely remove hardware".
5. Turn on the unit it should pass the 20 percent mark. When its good it has no file yet coz of format option. Just load your song.
I think it happens when too much file is upload in the unit. 60 percent of its capacity may be enough.
Hope it helps............
Jan 16, 2009 | Samsung YP-U2X Digital Media Player
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
Doesn't turn on correctly
you should reset it immediatly. you should see in an instruction maual how to do so.
Dec 27, 2008 | RCA Lyra RD2850 20 GB MP3 Player
System fail
I had the same problem with a YP-U3 and was able to fix it by installing upgrades from the Samsung website. First I downloaded an firmware upgrade from ver. 1.11 to ver. 1.13. The upgrade consists of two winzip files that need to be copied to the system folder on the YP-U3. After the two files were copied, the firmware upgraded itself when the MP3 player was turned on, but I still got a "system fail" message. Then I downloaded the latest version of Samsung Media Studio 5.2 from The Media Studio menu has a function for reformatting the MP3 player, which clears all data files but leaves the operating system intact. After that was done, the MP3 player worked properly.
Apr 14, 2008 | Samsung YP-U3 MP3 Player
Sansa e200 won't turn on
Load main image failed refers to a bad firmware file on the device. You can download and run this recovery tool from the SanDisk website. Best of Luck.
Sep 07, 2007 | SanDisk Sansa e200 MP3 Player
Failed to load system files...How can I reset?
To reset you need to have MP3 switched on, THEN hold the off switch for 10 seconds.If this fails to reset.You may have some corrupted music files sitting on the if you still have problems as i had the same issue and found a workaround.
Apr 22, 2007 | Thomson Lyra PDP2842U MP3 Player
RCA RD2820
you are going to need the Drivers for it I had the same problem then I got the Drivers and it works great just go to and download the two drivers and you should not have any problems
Jul 20, 2006 | RCA Lyra RD2820 20 GB MP3 Player
Failed to Load Files
I was able to access the play list using Windows Media Player. I was trying to get the computer to recognize the player, and it wouldn't do it. I even downloaded the Lyra Personal Audio Player updater... that didn't work or recognize the player.
Try the programs that are on your computer for playing MP3's.
Jun 12, 2006 | RCA Lyra RD2854 40 GB MP3 Player
Cannot turn on
You can reset your Lyra player at any time by depressing and continually holding the power button for a minimum of 10 seconds. Upon releasing of the power button, the unit should reset. If it does not, we recommend that you try again by depressing and holding the power button for up to 20 seconds. Constant pressure is required to depress the button for this duration. Second, download the latest firmware for your player. As for the unit freezing I figured out that it has to do with WMA files. try to re-coded your WMA's to MP3. I think it just has to do with the firmware not liking WMA very much. Use MP3 format only and I think you will be fine.
Jan 13, 2006 | RCA RD2826 MP3 Player
RCA Lyra RD2854 40 GB MP3 Player Logo
51 people viewed this question
Top RCA MP3 & Digital Media Players Experts
Gyula Lacz
Are you a RCA MP3 and Digital Media Player Expert? Answer questions, earn points and help others
